Retrieve CIFS session information for all SVMs
Retrieves information about CIFS sessions across all Storage Virtual Machines (SVMs). This helps you monitor and manage CIFS connections within your storage environment.
HTTP method and endpoint
GET /protocols/cifs/sessions
Introduced in
ONTAP 9.8
Usage notes
Retrieves the CIFS sessions information for all SVMs.
Related ONTAP commands
vserver cifs session show -active-volumes
Learn more
node.uuid |
string |
query |
False |
Filter by node.uuid |
node.name |
string |
query |
False |
Filter by node.name |
connected_duration |
string |
query |
False |
Filter by connected_duration |
idle_duration |
string |
query |
False |
Filter by idle_duration |
connection_id |
integer |
query |
False |
Filter by connection_id |
authentication |
string |
query |
False |
Filter by authentication |
mapped_unix_user |
string |
query |
False |
Filter by mapped_unix_user |
connection_count |
integer |
query |
False |
Filter by connection_count |
server_ip |
string |
query |
False |
Filter by server_ip |
large_mtu |
boolean |
query |
False |
Filter by large_mtu |
volumes.uuid |
string |
query |
False |
Filter by volumes.uuid |
volumes.name |
string |
query |
False |
Filter by volumes.name |
continuous_availability |
string |
query |
False |
Filter by continuous_availability |
smb_signing |
boolean |
query |
False |
Filter by smb_signing |
open_files |
integer |
query |
False |
Filter by open_files |
smb_encryption |
string |
query |
False |
Filter by smb_encryption |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
client_ip |
string |
query |
False |
Filter by client_ip |
protocol |
string |
query |
False |
Filter by protocol |
user |
string |
query |
False |
Filter by user |
open_shares |
integer |
query |
False |
Filter by open_shares |
identifier |
integer |
query |
False |
Filter by identifier |
open_other |
integer |
query |
False |
Filter by open_other |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[cifs_session] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"authentication": "ntlmv2",
"client_ip": "10.74.7.182",
"connected_duration": "P4DT84H30M5S",
"connection_count": 0,
"connection_id": 22802,
"continuous_availability": "unavailable",
"identifier": 4622663542519103507,
"idle_duration": "P4DT84H30M5S",
"large_mtu": true,
"mapped_unix_user": "root",
"node": {
"name": "node1",
"open_files": 0,
"open_other": 0,
"open_shares": 0,
"protocol": "smb3_1",
"server_ip": "10.140.78.248",
"smb_encryption": "unencrypted",
"smb_signing": "",
"svm": {
"name": "svm1",
"user": "NBCIFSQA2\\administrator",
"volumes": [
"name": "volume1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
node
_links |
name |
string |
uuid |
string |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
volumes
_links |
name |
string |
The name of the volume. |
uuid |
string |
cifs_session
_links |
authentication |
string |
SMB authentication over which the client accesses the share. The following values are supported:
client_ip |
string |
Specifies IP address of the client. |
string |
Specifies an ISO-8601 format of date and time used to retrieve the connected time duration in hours, minutes, and seconds format. |
connection_count |
integer |
A counter used to track requests that are sent to the volumes to the node. |
connection_id |
integer |
A unique 32-bit unsigned number used to represent each SMB session's connection ID. |
string |
The level of continuous availability protection provided to the SMB sessions and/or files.
identifier |
integer |
A unique 64-bit unsigned number used to represent each SMB session's identifier. |
idle_duration |
string |
Specifies an ISO-8601 format of date and time used to retrieve the idle time duration in hours, minutes, and seconds format. |
large_mtu |
boolean |
Specifies whether the large MTU is enabled or not for an SMB session. |
mapped_unix_user |
string |
Indicated that a mapped UNIX user has logged in. |
node |
open_files |
integer |
Number of files the SMB session has opened. |
open_other |
integer |
Number of other files the SMB session has opened. |
open_shares |
integer |
Number of shares the SMB session has opened. |
protocol |
string |
The SMB protocol version over which the client accesses the volumes. The following values are supported:
server_ip |
string |
Specifies the IP address of the SVM. |
smb_encryption |
string |
Indicates an SMB encryption state. The following values are supported:
smb_signing |
boolean |
Specifies whether or not SMB signing is enabled. |
svm |
user |
string |
Indicates that a Windows user has logged in. |
volumes |
array[volumes] |
A group of volumes, the client is accessing. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
