REST API reference
Retrieves the cifs sessions information for all svms
learn more
  • [doc /protocols/cifs/sessions](#docs-nas-protocols_cifs_sessions)
GET /protocols/cifs/sessions
Introduced In: 9.8
Retrieves the CIFS sessions information for all SVMs.
  • vserver cifs session show -active-volumes
server_ip
string
query
False
Filter by server_ip
connection_count
integer
query
False
Filter by connection_count
idle_duration
string
query
False
Filter by idle_duration
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
connected_duration
string
query
False
Filter by connected_duration
identifier
integer
query
False
Filter by identifier
protocol
string
query
False
Filter by protocol
continuous_availability
string
query
False
Filter by continuous_availability
open_files
integer
query
False
Filter by open_files
smb_signing
boolean
query
False
Filter by smb_signing
mapped_unix_user
string
query
False
Filter by mapped_unix_user
smb_encryption
string
query
False
Filter by smb_encryption
user
string
query
False
Filter by user
connection_id
integer
query
False
Filter by connection_id
node.name
string
query
False
Filter by node.name
node.uuid
string
query
False
Filter by node.uuid
open_shares
integer
query
False
Filter by open_shares
authentication
string
query
False
Filter by authentication
client_ip
string
query
False
Filter by client_ip
open_other
integer
query
False
Filter by open_other
volumes.uuid
string
query
False
Filter by volumes.uuid
volumes.name
string
query
False
Filter by volumes.name
large_mtu
boolean
query
False
Filter by large_mtu
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value: 1
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[cifs_session]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "authentication": "ntlmv2",
      "client_ip": "10.74.7.182",
      "connected_duration": "P4DT84H30M5S",
      "connection_count": "0",
      "connection_id": "22802",
      "continuous_availability": "unavailable",
      "identifier": "4622663542519103507",
      "idle_duration": "P4DT84H30M5S",
      "large_mtu": 1,
      "mapped_unix_user": "root",
      "node": {
        "name": "node1",
      "open_files": 0,
      "open_other": 0,
      "open_shares": 0,
      "protocol": "smb3_1",
      "server_ip": "10.140.78.248",
      "smb_encryption": "unencrypted",
      "smb_signing": "",
      "svm": {
        "name": "svm1",
      "user": "NBCIFSQA2\\administrator",
      "volumes": [
          "name": "volume1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
node
_links
_links
name
string
uuid
string
svm
_links
_links
name
string
The name of the SVM.
uuid
string
volumes
_links
_links
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
cifs_session
_links
_links
authentication
string
SMB authentication over which the client accesses the share. The following values are supported:
  • none - No authentication
  • ntlmv1 - Ntlm version 1 mechanism
  • ntlmv2 - Ntlm version 2 mechanism
  • kerberos - Kerberos authentication
  • anonymous - Anonymous mechanism
client_ip
string
Specifies IP address of the client.
connected_duration
string
Specifies an ISO-8601 format of date and time used to retrieve the connected time duration in hours, minutes, and seconds format.
connection_count
integer
A counter used to track requests that are sent to the volumes to the node.
connection_id
integer
A unique 32-bit unsigned number used to represent each SMB session's connection ID.
string
The level of continuous availabilty protection provided to the SMB sessions and/or files.
  • unavailable - Open file is not continuously available. For sessions, it contains one or more open files but none of them are continuously available.
  • available - open file is continuously available. For sessions, it contains one or more open files and all of them are continuously available.
  • partial - Sessions only. Contains at least one continuously available open file with other files open but not continuously available.
identifier
integer
A unique 64-bit unsigned number used to represent each SMB session's identifier.
idle_duration
string
Specifies an ISO-8601 format of date and time used to retrieve the idle time duration in hours, minutes, and seconds format.
large_mtu
boolean
Specifies whether the large MTU is enabled or not for an SMB session.
mapped_unix_user
string
Indicated that a mapped UNIX user has logged in.
node
node
open_files
integer
Number of files the SMB session has opened.
open_other
integer
Number of other files the SMB session has opened.
open_shares
integer
Number of shares the SMB session has opened.
protocol
string
The SMB protocol version over which the client accesses the volumes. The following values are supported:
  • smb1 - SMB version 1
  • smb2 - SMB version 2
  • smb2_1 - SMB version 2 minor version 1
  • smb3 - SMB version 3
  • smb3_1 - SMB version 3 minor version 1
server_ip
string
Specifies the IP address of the SVM.
smb_encryption
string
Indicates an SMB encryption state. The following values are supported:
  • unencrypted - SMB session is not encrypted
  • encrypted - SMB session is fully encrypted. SVM level encryption is enabled and encryption occurs for the entire session.
  • partially_encrypted - SMB session is partially encrypted. Share level encryption is enabled and encryption is initiated when the tree-connect occurs.
smb_signing
boolean
Specifies whether or not SMB signing is enabled.
svm
svm
user
string
Indicates that a Windows user has logged in.
volumes
array[volumes]
A group of volumes, the client is accessing.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
