REST API reference
Retrieve CIFS session information for all SVMs
GET /protocols/cifs/sessions
Introduced In: 9.8
Retrieves the CIFS sessions information for all SVMs.
  • vserver cifs session show -active-volumes
identifier
integer
query
False
Filter by identifier
mapped_unix_user
string
query
False
Filter by mapped_unix_user
smb_encryption
string
query
False
Filter by smb_encryption
server_ip
string
query
False
Filter by server_ip
connection_id
integer
query
False
Filter by connection_id
open_files
integer
query
False
Filter by open_files
connected_duration
string
query
False
Filter by connected_duration
node.uuid
string
query
False
Filter by node.uuid
node.name
string
query
False
Filter by node.name
authentication
string
query
False
Filter by authentication
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
open_shares
integer
query
False
Filter by open_shares
continuous_availability
string
query
False
Filter by continuous_availability
idle_duration
string
query
False
Filter by idle_duration
protocol
string
query
False
Filter by protocol
client_ip
string
query
False
Filter by client_ip
smb_signing
boolean
query
False
Filter by smb_signing
volumes.uuid
string
query
False
Filter by volumes.uuid
volumes.name
string
query
False
Filter by volumes.name
open_other
integer
query
False
Filter by open_other
connection_count
integer
query
False
Filter by connection_count
large_mtu
boolean
query
False
Filter by large_mtu
user
string
query
False
Filter by user
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value: 1
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[cifs_session]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "authentication": "ntlmv2",
      "client_ip": "10.74.7.182",
      "connected_duration": "P4DT84H30M5S",
      "connection_count": 0,
      "connection_id": 22802,
      "continuous_availability": "unavailable",
      "identifier": 4622663542519103507,
      "idle_duration": "P4DT84H30M5S",
      "large_mtu": true,
      "mapped_unix_user": "root",
      "node": {
        "name": "node1",
      "open_files": 0,
      "open_other": 0,
      "open_shares": 0,
      "protocol": "smb3_1",
      "server_ip": "10.140.78.248",
      "smb_encryption": "unencrypted",
      "smb_signing": "",
      "svm": {
        "name": "svm1",
      "user": "NBCIFSQA2\\administrator",
      "volumes": [
          "name": "volume1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
node
_links
_links
name
string
uuid
string
svm
_links
_links
name
string
uuid
string
volumes
_links
_links
name
string
The name of the volume. This field cannot be specified in a PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.8
  • x-nullable: true
cifs_session
_links
_links
authentication
string
SMB authentication over which the client accesses the share. The following values are supported:
  • none - No authentication
  • ntlmv1 - Ntlm version 1 mechanism
  • ntlmv2 - Ntlm version 2 mechanism
  • kerberos - Kerberos authentication
  • anonymous - Anonymous mechanism
client_ip
string
Specifies IP address of the client.
connected_duration
string
Specifies an ISO-8601 format of date and time used to retrieve the connected time duration in hours, minutes, and seconds format.
connection_count
integer
A counter used to track requests that are sent to the volumes to the node.
connection_id
integer
A unique 32-bit unsigned number used to represent each SMB session's connection ID.
string
The level of continuous availability protection provided to the SMB sessions and/or files.
  • unavailable - Open file is not continuously available. For sessions, it contains one or more open files but none of them are continuously available.
  • available - open file is continuously available. For sessions, it contains one or more open files and all of them are continuously available.
  • partial - Sessions only. Contains at least one continuously available open file with other files open but not continuously available.
identifier
integer
A unique 64-bit unsigned number used to represent each SMB session's identifier.
idle_duration
string
Specifies an ISO-8601 format of date and time used to retrieve the idle time duration in hours, minutes, and seconds format.
large_mtu
boolean
Specifies whether the large MTU is enabled or not for an SMB session.
mapped_unix_user
string
Indicated that a mapped UNIX user has logged in.
node
node
open_files
integer
Number of files the SMB session has opened.
open_other
integer
Number of other files the SMB session has opened.
open_shares
integer
Number of shares the SMB session has opened.
protocol
string
The SMB protocol version over which the client accesses the volumes. The following values are supported:
  • smb1 - SMB version 1
  • smb2 - SMB version 2
  • smb2_1 - SMB version 2 minor version 1
  • smb3 - SMB version 3
  • smb3_1 - SMB version 3 minor version 1
server_ip
string
Specifies the IP address of the SVM.
smb_encryption
string
Indicates an SMB encryption state. The following values are supported:
  • unencrypted - SMB session is not encrypted
  • encrypted - SMB session is fully encrypted. SVM level encryption is enabled and encryption occurs for the entire session.
  • partially_encrypted - SMB session is partially encrypted. Share level encryption is enabled and encryption is initiated when the tree-connect occurs.
smb_signing
boolean
Specifies whether or not SMB signing is enabled.
svm
svm
user
string
Indicates that a Windows user has logged in.
volumes
array[volumes]
A group of volumes, the client is accessing.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
