REST API reference
Retrieve FPolicy configuration for an SVM
Retrieves the FPolicy policy configuration for a storage virtual machine (SVM). This information helps you manage and apply consistent policy settings across your data SVMs within a cluster.
HTTP method and endpoint
GET /protocols/fpolicy/{svm.uuid}/policies
Introduced in
ONTAP 9.6
Usage notes
Retrieves the FPolicy policy configuration of an SVM. ONTAP allows the creation of a cluster level FPolicy policy that acts as a template for all the data SVMs belonging to the cluster. This cluster level FPolicy policy is also retrieved for the specified SVM.
  • fpolicy policy show
  • fpolicy policy scope show
privileged_user
string
query
False
Filter by privileged_user
  • Introduced in: 9.10
engine.name
string
query
False
Filter by engine.name
passthrough_read
boolean
query
False
Filter by passthrough_read
mandatory
boolean
query
False
Filter by mandatory
enabled
boolean
query
False
Filter by enabled
name
string
query
False
Filter by name
priority
integer
query
False
Filter by priority
  • Max value: 10
  • Min value: 1
allow_privileged_access
boolean
query
False
Filter by allow_privileged_access
  • Introduced in: 9.13
scope.include_volumes
string
query
False
Filter by scope.include_volumes
scope.check_extensions_on_directories
boolean
query
False
Filter by scope.check_extensions_on_directories
  • Introduced in: 9.11
scope.include_export_policies
string
query
False
Filter by scope.include_export_policies
scope.exclude_export_policies
string
query
False
Filter by scope.exclude_export_policies
scope.include_shares
string
query
False
Filter by scope.include_shares
scope.exclude_volumes
string
query
False
Filter by scope.exclude_volumes
scope.exclude_extension
string
query
False
Filter by scope.exclude_extension
scope.include_extension
string
query
False
Filter by scope.include_extension
scope.exclude_shares
string
query
False
Filter by scope.exclude_shares
scope.object_monitoring_with_no_extension
boolean
query
False
Filter by scope.object_monitoring_with_no_extension
events.name
string
query
False
Filter by events.name
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Max value: 120
  • Min value: 0
  • Default value: 15
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of Records
records
array[fpolicy_policy]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "engine": {
        "name": "string"
      "events": [
        "event_nfs_close",
        "event_open"
      "name": "fp_policy_1",
      "privileged_user": "mydomain\\testuser",
      "scope": {
        "exclude_export_policies": [
          "string"
        "exclude_extension": [
          "string"
        "exclude_shares": [
          "string"
        "exclude_volumes": [
          "vol1",
          "vol_svm1",
        "include_export_policies": [
          "string"
        "include_extension": [
          "string"
        "include_shares": [
          "sh1",
          "share_cifs"
        "include_volumes": [
          "vol1",
          "vol_svm1"
      "svm": {
        "uuid": "string"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
fpolicy_engine_reference
FPolicy external engine
_links
_links
name
string
The name of the FPolicy external engine.
fpolicy_event_reference
FPolicy events
_links
_links
name
string
scope
boolean
Specifies whether the file name extension checks also apply to directory objects. If this parameter is set to true, the directory objects are subjected to the same extension checks as regular files. If this parameter is set to false, the directory names are not matched for extensions and notifications are sent for directories even if their name extensions do not match. Default is false.
array[string]
exclude_extension
array[string]
exclude_shares
array[string]
exclude_volumes
array[string]
array[string]
include_extension
array[string]
include_shares
array[string]
include_volumes
array[string]
boolean
Specifies whether the extension checks also apply to objects with no extension. If this parameter is set to true, all objects with or without extensions are monitored. Default is false.
svm
uuid
string
SVM UUID
fpolicy_policy
boolean
Specifies whether privileged access is required for FPolicy servers. Privileged access is used when the FPolicy server requires direct access to the cluster nodes. When this parameter is set to true, FPolicy servers can access files on the cluster using a separate data channel with privileged access.
enabled
boolean
Specifies if the policy is enabled on the SVM or not. If no value is mentioned for this field but priority is set, then this policy will be enabled.
engine
events
array[fpolicy_event_reference]
mandatory
boolean
Specifies what action to take on a file access event in a case when all primary and secondary servers are down or no response is received from the FPolicy servers within a given timeout period. When this parameter is set to true, file access events will be denied under these circumstances.
name
string
Specifies the name of the policy.
passthrough_read
boolean
Specifies whether passthrough-read should be allowed for FPolicy servers registered for the policy. Passthrough-read is a way to read data for offline files without restoring the files to primary storage. Offline files are files that have been moved to secondary storage.
priority
integer
Specifies the priority that is assigned to this policy.
privileged_user
string
Specifies the privileged user name for accessing files on the cluster using a separate data channel with privileged access. The input for this field should be in "domain\username" format.
scope
scope
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
