Retrieve an FPolicy configuration for an SVM
Retrieves the FPolicy policy configuration for a specific SVM to understand and manage its policy settings within the cluster. This helps ensure that the SVM aligns with the cluster-level FPolicy template.
HTTP method and endpoint
GET /protocols/fpolicy/{svm.uuid}/policies
Introduced in
ONTAP 9.6
Usage notes
Retrieves the FPolicy policy configuration of an SVM. ONTAP allows the creation of a cluster level FPolicy policy that acts as a template for all the data SVMs belonging to the cluster. This cluster level FPolicy policy is also retrieved for the specified SVM.
Related ONTAP commands
fpolicy policy show -
fpolicy policy scope show
Learn more
persistent_store |
string |
query |
False |
Filter by persistent_store
allow_privileged_access |
boolean |
query |
False |
Filter by allow_privileged_access
name |
string |
query |
False |
Filter by name |
scope.exclude_volumes |
string |
query |
False |
Filter by scope.exclude_volumes |
scope.include_shares |
string |
query |
False |
Filter by scope.include_shares |
scope.exclude_extension |
string |
query |
False |
Filter by scope.exclude_extension |
scope.include_extension |
string |
query |
False |
Filter by scope.include_extension |
scope.include_volumes |
string |
query |
False |
Filter by scope.include_volumes |
scope.object_monitoring_with_no_extension |
boolean |
query |
False |
Filter by scope.object_monitoring_with_no_extension
scope.include_export_policies |
string |
query |
False |
Filter by scope.include_export_policies |
scope.exclude_export_policies |
string |
query |
False |
Filter by scope.exclude_export_policies |
scope.check_extensions_on_directories |
boolean |
query |
False |
Filter by scope.check_extensions_on_directories
scope.exclude_shares |
string |
query |
False |
Filter by scope.exclude_shares |
passthrough_read |
boolean |
query |
False |
Filter by passthrough_read
events.name |
string |
query |
False |
Filter by events.name |
privileged_user |
string |
query |
False |
Filter by privileged_user
priority |
integer |
query |
False |
Filter by priority
enabled |
boolean |
query |
False |
Filter by enabled |
mandatory |
boolean |
query |
False |
Filter by mandatory |
engine.name |
string |
query |
False |
Filter by engine.name |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of Records |
records |
array[fpolicy_policy] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"engine": {
"name": "string"
"events": [
"event_cifs",
"event_open"
"name": "fp_policy_1",
"persistent_store": "ps1",
"priority": 1,
"privileged_user": "mydomain\\testuser",
"scope": {
"exclude_export_policies": [
"string"
"exclude_extension": [
"string"
"exclude_shares": [
"string"
"exclude_volumes": [
"vol1",
"vol_svm1",
"include_export_policies": [
"string"
"include_extension": [
"string"
"include_shares": [
"sh1",
"share_cifs"
"include_volumes": [
"vol1",
"vol_svm1"
"svm": {
"uuid": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
fpolicy_engine_reference
FPolicy external engine
_links |
name |
string |
The name of the FPolicy external engine. |
fpolicy_event_reference
FPolicy events
_links |
name |
string |
scope
boolean |
Specifies whether the file name extension checks also apply to directory objects. If this parameter is set to true, the directory objects are subjected to the same extension checks as regular files. If this parameter is set to false, the directory names are not matched for extensions and notifications are sent for directories even if their name extensions do not match. Default is false. |
array[string] |
exclude_extension |
array[string] |
exclude_shares |
array[string] |
exclude_volumes |
array[string] |
array[string] |
include_extension |
array[string] |
include_shares |
array[string] |
include_volumes |
array[string] |
boolean |
Specifies whether the extension checks also apply to objects with no extension. If this parameter is set to true, all objects with or without extensions are monitored. Default is false. |
svm
uuid |
string |
SVM UUID |
fpolicy_policy
boolean |
Specifies whether privileged access is required for FPolicy servers. Privileged access is used when the FPolicy server requires direct access to the cluster nodes. When this parameter is set to true, FPolicy servers can access files on the cluster using a separate data channel with privileged access. |
enabled |
boolean |
Specifies if the policy is enabled on the SVM or not. If no value is mentioned for this field but priority is set, then this policy will be enabled. |
engine |
FPolicy external engine |
events |
array[fpolicy_event_reference] |
mandatory |
boolean |
Specifies what action to take on a file access event in a case when all primary and secondary servers are down or no response is received from the FPolicy servers within a given timeout period. When this parameter is set to true, file access events will be denied under these circumstances. |
name |
string |
Specifies the name of the policy. |
passthrough_read |
boolean |
Specifies whether passthrough-read should be allowed for FPolicy servers registered for the policy. Passthrough-read is a way to read data for offline files without restoring the files to primary storage. Offline files are files that have been moved to secondary storage. |
persistent_store |
string |
Specifies the persistent storage name. This can then be used to enable persistent mode for FPolicy events. |
priority |
integer |
Specifies the priority that is assigned to this policy. |
privileged_user |
string |
Specifies the privileged user name for accessing files on the cluster using a separate data channel with privileged access. The input for this field should be in "domain\username" format. |
scope |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
