REST API reference
Retrieves the fpolicy policy configuration of an svm ontap allows the creation of a cluster level fpolicy policy that acts as a template for all the data svms belonging to the cluster this cluster level fpolicy policy is also retrieved for the specified svm
  • fpolicy policy scope show # learn more
  • [doc /protocols/fpolicy/{svmuuid}/policies](#docs-nas-protocols_fpolicy_{svmuuid}_policies)
GET /protocols/fpolicy/{svm.uuid}/policies
Retrieves the FPolicy policy configuration of an SVM. ONTAP allows the creation of a cluster level FPolicy policy that acts as a template for all the data SVMs belonging to the cluster. This cluster level FPolicy policy is also retrieved for the specified SVM.
  • fpolicy policy show
svm.uuid
string
path
True
enabled
boolean
query
False
Filter by enabled
scope.exclude_export_policies
string
query
False
Filter by scope.exclude_export_policies
scope.exclude_extension
string
query
False
Filter by scope.exclude_extension
scope.include_volumes
string
query
False
Filter by scope.include_volumes
scope.include_shares
string
query
False
Filter by scope.include_shares
scope.exclude_volumes
string
query
False
Filter by scope.exclude_volumes
scope.include_extension
string
query
False
Filter by scope.include_extension
scope.exclude_shares
string
query
False
Filter by scope.exclude_shares
scope.include_export_policies
string
query
False
Filter by scope.include_export_policies
events.name
string
query
False
Filter by events.name
priority
integer
query
False
Filter by priority
mandatory
boolean
query
False
Filter by mandatory
name
string
query
False
Filter by name
engine.name
string
query
False
Filter by engine.name
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
return_timeout
integer
query
False
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of Records
records
array[fpolicy_policy]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "engine": {
        "name": "string"
      "events": [
        "event_nfs_close",
        "event_open"
      "name": "fp_policy_1",
      "scope": {
        "exclude_export_policies": [
          "string"
        "exclude_extension": [
          "string"
        "exclude_shares": [
          "string"
        "exclude_volumes": [
          "vol1",
          "vol_svm1",
        "include_export_policies": [
          "string"
        "include_extension": [
          "string"
        "include_shares": [
          "sh1",
          "share_cifs"
        "include_volumes": [
          "vol1",
          "vol_svm1"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
fpolicy_engine_reference
FPolicy external engine
_links
_links
name
string
The name of the FPolicy external engine.
fpolicy_event_reference
FPolicy events
_links
_links
name
string
scope
array[string]
exclude_extension
array[string]
exclude_shares
array[string]
exclude_volumes
array[string]
array[string]
include_extension
array[string]
include_shares
array[string]
include_volumes
array[string]
fpolicy_policy
enabled
boolean
Specifies if the policy is enabled on the SVM or not. If no value is mentioned for this field but priority is set, then this policy will be enabled.
engine
events
array[fpolicy_event_reference]
mandatory
boolean
Specifies what action to take on a file access event in a case when all primary and secondary servers are down or no response is received from the FPolicy servers within a given timeout period. When this parameter is set to true, file access events will be denied under these circumstances.
name
string
Specifies the name of the policy.
priority
integer
Specifies the priority that is assigned to this policy.
scope
scope
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
