Retrieve the FPolicy configuration for an SVM
GET /protocols/fpolicy/{svm.uuid}/policies
Introduced In: 9.6
Retrieves the FPolicy policy configuration of an SVM. ONTAP allows the creation of a cluster level FPolicy policy that acts as a template for all the data SVMs belonging to the cluster. This cluster level FPolicy policy is also retrieved for the specified SVM.
Related ONTAP commands
fpolicy policy show -
fpolicy policy scope show
Learn more
enabled |
boolean |
query |
False |
Filter by enabled |
scope.exclude_volumes |
string |
query |
False |
Filter by scope.exclude_volumes |
scope.include_export_policies |
string |
query |
False |
Filter by scope.include_export_policies |
scope.exclude_shares |
string |
query |
False |
Filter by scope.exclude_shares |
scope.include_volumes |
string |
query |
False |
Filter by scope.include_volumes |
scope.include_extension |
string |
query |
False |
Filter by scope.include_extension |
scope.exclude_extension |
string |
query |
False |
Filter by scope.exclude_extension |
scope.exclude_export_policies |
string |
query |
False |
Filter by scope.exclude_export_policies |
scope.include_shares |
string |
query |
False |
Filter by scope.include_shares |
priority |
integer |
query |
False |
Filter by priority |
events.name |
string |
query |
False |
Filter by events.name |
engine.name |
string |
query |
False |
Filter by engine.name |
mandatory |
boolean |
query |
False |
Filter by mandatory |
name |
string |
query |
False |
Filter by name |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of Records |
records |
array[fpolicy_policy] |
"next": {
"href": "/api/resourcelink"
"records": [
"engine": {
"name": "string"
"events": [
"event_nfs_close",
"event_open"
"name": "fp_policy_1",
"scope": {
"exclude_export_policies": [
"string"
"exclude_extension": [
"string"
"exclude_shares": [
"string"
"exclude_volumes": [
"vol1",
"vol_svm1",
"include_export_policies": [
"string"
"include_extension": [
"string"
"include_shares": [
"sh1",
"share_cifs"
"include_volumes": [
"vol1",
"vol_svm1"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
fpolicy_engine_reference
FPolicy external engine
_links |
name |
string |
The name of the FPolicy external engine. |
fpolicy_event_reference
FPolicy events
_links |
name |
string |
scope
array[string] |
exclude_extension |
array[string] |
exclude_shares |
array[string] |
exclude_volumes |
array[string] |
array[string] |
include_extension |
array[string] |
include_shares |
array[string] |
include_volumes |
array[string] |
fpolicy_policy
enabled |
boolean |
Specifies if the policy is enabled on the SVM or not. If no value is mentioned for this field but priority is set, then this policy will be enabled. |
engine |
FPolicy external engine |
events |
array[fpolicy_event_reference] |
mandatory |
boolean |
Specifies what action to take on a file access event in a case when all primary and secondary servers are down or no response is received from the FPolicy servers within a given timeout period. When this parameter is set to true, file access events will be denied under these circumstances. |
name |
string |
Specifies the name of the policy. |
priority |
integer |
Specifies the priority that is assigned to this policy. |
scope |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
