Retrieve NFS connected-client cache settings for a cluster
Accesses the NFS connected-client cache settings for a cluster. This information helps you understand the current cache configuration and manage client interactions with the NFS service effectively.
HTTP method and endpoint
GET /protocols/nfs/connected-client-settings
Introduced in
ONTAP 9.12
Usage notes
Retrieves the NFS connected-client cache settings of the cluster.
enable_nfs_clients_deletion |
boolean |
query |
False |
Filter by enable_nfs_clients_deletion |
client_retention_interval |
string |
query |
False |
Filter by client_retention_interval |
update_interval |
string |
query |
False |
Filter by update_interval |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
string |
The lifetime range of the connected-clients cache. Only intervals in multiples of 12 hours or its equivalent in days, minutes or seconds are supported. The minimum is 12 hours and the maximum is 168 hours or 7 days. |
boolean |
Specifies whether or not NFS Clients deletion is enabled for the connected-clients cache. When set to "true", connected-clients entries are deleted when a connection is closed. |
update_interval |
string |
The time interval between refreshing the connected-clients cache. The minimum is 1 hour and the maximum is 8 hours. |
"href": "/api/resourcelink"
"client_retention_interval": "string",
"update_interval": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
