REST API reference
Retrieve the NFS connected-client cache settings for a cluster
Retrieves the NFS connected-client cache settings for a cluster to understand the current cache configuration.
HTTP method and endpoint
GET /protocols/nfs/connected-client-settings
Introduced in
ONTAP 9.12
Usage notes
Retrieves the NFS connected-client cache settings of the cluster.
enable_nfs_clients_deletion
boolean
query
False
Filter by enable_nfs_clients_deletion
client_retention_interval
string
query
False
Filter by client_retention_interval
update_interval
string
query
False
Filter by update_interval
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
string
The lifetime range of the connected-clients cache. Only intervals in multiples of 12 hours or its equivalent in days, minutes or seconds are supported. The minimum is 12 hours and the maximum is 168 hours or 7 days.
boolean
Specifies whether or not NFS Clients deletion is enabled for the connected-clients cache. When set to "true", connected-clients entries are deleted when a connection is closed.
update_interval
string
The time interval between refreshing the connected-clients cache. The minimum is 1 hour and the maximum is 8 hours.
      "href": "/api/resourcelink"
  "client_retention_interval": "string",
  "update_interval": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
