Retrieve the NFS connected-client cache settings for a cluster
Accesses the NFS connected-client cache settings for a cluster to review its configuration.
HTTP method and endpoint
GET /protocols/nfs/connected-client-settings
Introduced in
ONTAP 9.12
Usage notes
Retrieves the NFS connected-client cache settings of the cluster.
update_interval |
string |
query |
False |
Filter by update_interval |
client_retention_interval |
string |
query |
False |
Filter by client_retention_interval |
enable_nfs_clients_deletion |
boolean |
query |
False |
Filter by enable_nfs_clients_deletion |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
string |
The lifetime range of the connected-clients cache. Only intervals in multiples of 12 hours or its equivalent in days, minutes or seconds are supported. The minimum is 12 hours and the maximum is 168 hours or 7 days. |
boolean |
Specifies whether or not NFS Clients deletion is enabled for the connected-clients cache. When set to "true", connected-clients entries are deleted when a connection is closed. |
update_interval |
string |
The time interval between refreshing the connected-clients cache. The minimum is 1 hour and the maximum is 8 hours. |
"href": "/api/resourcelink"
"client_retention_interval": "string",
"update_interval": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
