Retrieve export policy rules
Retrieves export policy rules to understand the access permissions configured for your storage resources. This helps you manage and verify export policies effectively.
HTTP method and endpoint
GET /protocols/nfs/export-policies/{policy.id}/rules
Introduced in
ONTAP 9.6
Related ONTAP commands
vserver export-policy rule show
Learn more
policy.id |
integer |
path |
True |
Export Policy ID |
rw_rule |
string |
query |
False |
Filter by rw_rule |
clients.match |
string |
query |
False |
Filter by clients.match |
allow_suid |
boolean |
query |
False |
Filter by allow_suid
chown_mode |
string |
query |
False |
Filter by chown_mode
allow_device_creation |
boolean |
query |
False |
Filter by allow_device_creation
protocols |
string |
query |
False |
Filter by protocols |
ntfs_unix_security |
string |
query |
False |
Filter by ntfs_unix_security
superuser |
string |
query |
False |
Filter by superuser |
anonymous_user |
string |
query |
False |
Filter by anonymous_user |
index |
integer |
query |
False |
Filter by index |
policy.name |
string |
query |
False |
Filter by policy.name
ro_rule |
string |
query |
False |
Filter by ro_rule |
svm.uuid |
string |
query |
False |
Filter by svm.uuid
svm.name |
string |
query |
False |
Filter by svm.name
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of Export Rule records |
records |
array[export_rule] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"anonymous_user": "string",
"chown_mode": "string",
"clients": [
"match": "0.0.0.0/0"
"index": 0,
"ntfs_unix_security": "string",
"policy": {
"name": "string"
"protocols": [
"string"
"ro_rule": [
"string"
"rw_rule": [
"string"
"superuser": [
"string"
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
export_clients
match |
string |
Client Match Hostname, IP Address, Netgroup, or Domain. You can specify the match as a string value in any of the following formats:
policy
id |
integer |
Export policy ID |
name |
string |
Export policy name |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
export_rule
_links |
boolean |
Specifies whether or not device creation is allowed. |
allow_suid |
boolean |
Specifies whether or not SetUID bits in SETATTR Op is to be honored. |
anonymous_user |
string |
User ID To Which Anonymous Users Are Mapped. |
chown_mode |
string |
Specifies who is authorized to change the ownership mode of a file. |
clients |
array[export_clients] |
Array of client matches |
index |
integer |
Index of the rule within the export policy. |
string |
NTFS export UNIX security options. |
policy |
protocols |
array[string] |
ro_rule |
array[string] |
Authentication flavors that the read-only access rule governs |
rw_rule |
array[string] |
Authentication flavors that the read/write access rule governs |
superuser |
array[string] |
Authentication flavors that the superuser security type governs |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
