Retrieve export policy rules
Retrieves export policy rules to view the current configuration for managing access to NFS or CIFS resources.
HTTP method and endpoint
GET /protocols/nfs/export-policies/{policy.id}/rules
Introduced in
ONTAP 9.6
Related ONTAP commands
vserver export-policy rule show
Learn more
policy.id |
integer |
path |
True |
Export Policy ID |
ntfs_unix_security |
string |
query |
False |
Filter by ntfs_unix_security
superuser |
string |
query |
False |
Filter by superuser |
protocols |
string |
query |
False |
Filter by protocols |
svm.uuid |
string |
query |
False |
Filter by svm.uuid
svm.name |
string |
query |
False |
Filter by svm.name
ro_rule |
string |
query |
False |
Filter by ro_rule |
allow_nfs_tls_only |
boolean |
query |
False |
Filter by allow_nfs_tls_only
anonymous_user |
string |
query |
False |
Filter by anonymous_user |
allow_suid |
boolean |
query |
False |
Filter by allow_suid
policy.name |
string |
query |
False |
Filter by policy.name
rw_rule |
string |
query |
False |
Filter by rw_rule |
clients.match |
string |
query |
False |
Filter by clients.match |
index |
integer |
query |
False |
Filter by index |
allow_device_creation |
boolean |
query |
False |
Filter by allow_device_creation
chown_mode |
string |
query |
False |
Filter by chown_mode
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of Export Rule records |
records |
array[export_rule] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"anonymous_user": "string",
"chown_mode": "string",
"clients": [
"match": "0.0.0.0/0"
"ntfs_unix_security": "string",
"policy": {
"name": "string"
"protocols": [
"string"
"ro_rule": [
"string"
"rw_rule": [
"string"
"superuser": [
"string"
"svm": {
"name": "svm1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
262194 |
The expression is missing a value |
262197 |
The value provided is invalid for the field |
2621462 |
The specified SVM name does not exist |
2621519 |
SVM name is invalid. The SVM name must begin with a letter or an underscore. If the SVM is of type "sync-source", the maximum supported length is 41. Otherwise, the maximum supported length is 47 |
2621643 |
The specified SVM name is too long |
2621685 |
SVM name length cannot be zero |
2621706 |
The specified SVM UUID is incorrect for the specified SVM name |
6691623 |
User is not authorized |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
export_clients
match |
string |
Client Match Hostname, IP Address, Netgroup, or Domain. You can specify the match as a string value in any of the following formats:
policy
id |
integer |
Export policy ID |
name |
string |
Export policy name |
svm
_links |
name |
string |
uuid |
string |
export_rule
_links |
boolean |
Specifies whether or not device creation is allowed. |
boolean |
Specifies whether to allow NFS access only over TLS connections. |
allow_suid |
boolean |
Specifies whether or not SetUID bits in SETATTR Op is to be honored. |
anonymous_user |
string |
User ID To Which Anonymous Users Are Mapped. |
chown_mode |
string |
Specifies who is authorized to change the ownership mode of a file. |
clients |
array[export_clients] |
Array of client matches |
index |
integer |
Index of the rule within the export policy. |
string |
NTFS export UNIX security options. |
policy |
protocols |
array[string] |
ro_rule |
array[string] |
Authentication flavors that the read-only access rule governs |
rw_rule |
array[string] |
Authentication flavors that the read/write access rule governs |
superuser |
array[string] |
Authentication flavors that the superuser security type governs |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
