REST API reference
Retrieve export policy rules
Retrieves export policy rules to view the existing configurations for managing access to your storage resources. Use this endpoint to ensure that your export policies align with your security and access requirements.
HTTP method and endpoint
GET /protocols/nfs/export-policies/{policy.id}/rules
Introduced in
ONTAP 9.6
  • vserver export-policy rule show
policy.id
integer
path
True
Export Policy ID
ro_rule
string
query
False
Filter by ro_rule
clients.match
string
query
False
Filter by clients.match
svm.uuid
string
query
False
Filter by svm.uuid
  • Introduced in: 9.10
svm.name
string
query
False
Filter by svm.name
chown_mode
string
query
False
Filter by chown_mode
  • Introduced in: 9.9
superuser
string
query
False
Filter by superuser
anonymous_user
string
query
False
Filter by anonymous_user
allow_device_creation
boolean
query
False
Filter by allow_device_creation
allow_suid
boolean
query
False
Filter by allow_suid
protocols
string
query
False
Filter by protocols
policy.name
string
query
False
Filter by policy.name
index
integer
query
False
Filter by index
ntfs_unix_security
string
query
False
Filter by ntfs_unix_security
rw_rule
string
query
False
Filter by rw_rule
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of Export Rule records
records
array[export_rule]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "anonymous_user": "string",
      "chown_mode": "string",
      "clients": [
          "match": "0.0.0.0/0"
      "index": 0,
      "ntfs_unix_security": "string",
      "policy": {
        "name": "string"
      "protocols": [
        "string"
      "ro_rule": [
        "string"
      "rw_rule": [
        "string"
      "superuser": [
        "string"
      "svm": {
        "name": "svm1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
export_clients
match
string
Client Match Hostname, IP Address, Netgroup, or Domain. You can specify the match as a string value in any of the following formats:
  • As a hostname; for instance, host1
  • As an IPv4 address; for instance, 10.1.12.24
  • As an IPv6 address; for instance, fd20:8b1e:b255:4071::100:1
  • As an IPv4 address with a subnet mask expressed as a number of bits; for instance, 10.1.12.0/24
  • As an IPv6 address with a subnet mask expressed as a number of bits; for instance, fd20:8b1e:b255:4071::/64
  • As an IPv4 address with a network mask; for instance, 10.1.16.0/255.255.255.0
  • As a netgroup, with the netgroup name preceded by the @ character; for instance, @eng
  • As a domain name preceded by the . character; for instance, .example.com
policy
id
integer
Export policy ID
name
string
Export policy name
svm
_links
_links
name
string
The name of the SVM.
uuid
string
export_rule
_links
_links
boolean
Specifies whether or not device creation is allowed.
allow_suid
boolean
Specifies whether or not SetUID bits in SETATTR Op is to be honored.
anonymous_user
string
User ID To Which Anonymous Users Are Mapped.
chown_mode
string
Specifies who is authorized to change the ownership mode of a file.
clients
array[export_clients]
Array of client matches
index
integer
Index of the rule within the export policy.
ntfs_unix_security
string
NTFS export UNIX security options.
policy
policy
protocols
array[string]
ro_rule
array[string]
Authentication flavors that the read-only access rule governs
rw_rule
array[string]
Authentication flavors that the read/write access rule governs
superuser
array[string]
Authentication flavors that the superuser security type governs
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
