Retrieve the S3 bucket configuration for an SVM
Retrieves the S3 bucket configuration for a storage virtual machine (SVM) to understand how buckets are set up and managed. This is useful for reviewing and verifying policy conditions and management rules associated with the S3 buckets.
HTTP method and endpoint
GET /protocols/s3/buckets/{svm.uuid}/{uuid}
Introduced in
ONTAP 9.8
Usage notes
Retrieves the S3 bucket configuration of an SVM. Note that in order to retrieve S3 bucket policy conditions, the 'fields' option should be set to '**'.
Related ONTAP commands
vserver object-store-server bucket show -
vserver object-store-server bucket policy statement show -
vserver object-store-server bucket policy-statement-condition show -
vserver object-store-server bucket lifecycle-management-rule show
Learn more
uuid |
string |
path |
True |
The unique identifier of the bucket. |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
allowed |
boolean |
If this is set to true, an SVM administrator can manage the S3 service. If it is false, only the cluster administrator can manage the service. |
audit_event_selector |
Audit event selector allows you to specify access and permission types to audit. |
comment |
string |
Can contain any additional information about the bucket being created or modified. |
encryption |
lifecycle_management |
Lifecycle management is implemented as an object associated with a bucket. It defines rules to be applied against objects within a bucket. These rules are applied in the background and can delete objects. |
logical_used_size |
integer |
Specifies the bucket logical used size up to this point. |
name |
string |
Specifies the name of the bucket. Bucket name is a string that can only contain the following combination of ASCII-range alphanumeric characters 0-9, a-z, ".", and "-". |
nas_path |
string |
Specifies the NAS path to which the nas bucket corresponds to. |
policy |
A policy is an object associated with a bucket. It defines resource (bucket, folder, or object) permissions. These policies get evaluated when an S3 user makes a request by executing a specific command. The user must be part of the principal (user or group) specified in the policy. Permissions in the policies determine whether the request is allowed or denied. |
protection_status |
Specifies attributes of bucket protection. |
qos_policy |
Specifes "qos_policy.max_throughput_iops" and/or "qos_policy.max_throughput_mbps" or "qos_policy.min_throughput_iops" and/or "qos_policy.min_throughput_mbps". Specifying "min_throughput_iops" or "min_throughput_mbps" is only supported on volumes hosted on a node that is flash optimized. A pre-created QoS policy can also be used by specifying "qos_policy.name" or "qos_policy.uuid" properties. Setting or assigning a QoS policy to a bucket is not supported if its containing volume or SVM already has a QoS policy attached. |
role |
string |
Specifies the role of the bucket. |
size |
integer |
Specifies the bucket size in bytes; ranges from 80MB to 64TB. |
svm |
type |
string |
Specifies the bucket type. Valid values are "s3"and "nas". |
uuid |
string |
Specifies the unique identifier of the bucket. |
versioning_state |
string |
Specifies the versioning state of the bucket. Valid values are "disabled", "enabled" or "suspended". Note that the versioning state cannot be modified to 'disabled' from any other state. |
volume |
Specifies the FlexGroup volume name and UUID where the bucket is hosted. |
"audit_event_selector": {
"access": "string",
"permission": "string"
"comment": "S3 bucket.",
"lifecycle_management": {
"rules": [
"href": "/api/resourcelink"
"abort_incomplete_multipart_upload": {
"expiration": {
"object_expiry_date": "string"
"name": "string",
"non_current_version_expiration": {
"object_filter": {
"prefix": "/logs",
"size_greater_than": 10485760,
"size_less_than": 10240,
"tags": [
"project1=projA",
"project2=projB"
"logical_used_size": 0,
"name": "bucket1",
"nas_path": "/",
"policy": {
"statements": [
"actions": [
"GetObject",
"PutObject",
"DeleteObject",
"ListBucket"
"conditions": [
"delimiters": [
"max_keys": [
1000
"operator": "ip_address",
"prefixes": [
"pref"
"source_ips": [
"1.1.1.1",
"1.2.2.0/24"
"usernames": [
"user1"
"effect": "allow",
"principals": [
"user1",
"group/grp1"
"resources": [
"bucket1",
"bucket1/*"
"sid": "FullAccessToUser1"
"qos_policy": {
"max_throughput_iops": 10000,
"max_throughput_mbps": 500,
"min_throughput_iops": 2000,
"min_throughput_mbps": 500,
"name": "performance",
"role": "string",
"size": 1677721600,
"svm": {
"name": "svm1",
"type": "s3",
"uuid": "414b29a1-3b26-11e9-bd58-0050568ea055",
"versioning_state": "enabled",
"volume": {
"name": "volume1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
aggregates
_links |
name |
string |
uuid |
string |
access |
string |
Specifies read and write access types. |
permission |
string |
Specifies allow and deny permission types. |
encryption
enabled |
boolean |
Specifies whether encryption is enabled on the bucket. By default, encryption is disabled on a bucket. |
Specifies a way to perform abort_incomplete_multipart_upload action on filtered objects within a bucket.
_links |
after_initiation_days |
integer |
Number of days of initiation after which uploads can be aborted. |
expiration
Specifies a way to perform expiration action on filtered objects within a bucket.
_links |
expired_object_delete_marker |
boolean |
Cleanup object delete markers. |
object_age_days |
integer |
Number of days since creation after which objects can be deleted. |
object_expiry_date |
string |
Specific date from when objects can expire. |
Specifies a way to perform non_current_version_expiration action on filtered objects within a bucket.
_links |
new_non_current_versions |
integer |
Number of latest non-current versions to be retained. |
non_current_days |
integer |
Number of days after which non-current versions can be deleted. |
object_filter
Specifies a way to filter objects within a bucket.
_links |
prefix |
string |
A prefix that is matched against object-names within a bucket. |
size_greater_than |
integer |
Size of the object greater than specified for which the corresponding lifecycle rule is to be applied. |
size_less_than |
integer |
Size of the object smaller than specified for which the corresponding lifecycle rule is to be applied. |
tags |
array[string] |
An array of key-value paired tags of the form |
rules
Information about the lifecycle management rule of a bucket.
_links |
abort_incomplete_multipart_upload |
Specifies a way to perform abort_incomplete_multipart_upload action on filtered objects within a bucket. |
enabled |
boolean |
Specifies whether or not the associated rule is enabled. |
expiration |
Specifies a way to perform expiration action on filtered objects within a bucket. |
name |
string |
Bucket lifecycle management rule identifier. |
non_current_version_expiration |
Specifies a way to perform non_current_version_expiration action on filtered objects within a bucket. |
object_filter |
Specifies a way to filter objects within a bucket. |
rules |
array[rules] |
Specifies an object store lifecycle management policy. |
s3_bucket_policy_condition
Information about policy conditions based on various condition operators and condition keys.
delimiters |
array[string] |
An array of delimiters that are compared with the delimiter value specified at the time of execution of an S3-based command, using the condition operator specified. |
max_keys |
array[integer] |
An array of maximum keys that are allowed or denied to be retrieved using an S3 list operation, based on the condition operator specified. |
operator |
string |
Condition operator that is applied to the specified condition key. |
prefixes |
array[string] |
An array of prefixes that are compared with the input prefix value specified at the time of execution of an S3-based command, using the condition operator specified. |
source_ips |
array[string] |
An array of IP address ranges that are compared with the IP address of a source command at the time of execution of an S3-based command, using the condition operator specified. |
usernames |
array[string] |
An array of usernames that a current user in the context is evaluated against using the condition operators. |
s3_bucket_policy_statement
Specifies information about a single access permission.
actions |
array[string] |
conditions |
array[s3_bucket_policy_condition] |
Specifies bucket policy conditions. |
effect |
string |
Specifies whether access is allowed or denied when a user requests the specific action. If access (to allow) is not granted explicitly to a resource, access is implicitly denied. Access can also be denied explicitly to a resource, in order to make sure that a user cannot access it, even if a different policy grants access. |
principals |
array[string] |
resources |
array[string] |
sid |
string |
Specifies the statement identifier used to differentiate between statements. |
policy
statements |
array[s3_bucket_policy_statement] |
Specifies bucket access policy statement. |
destination
is_cloud |
boolean |
Specifies whether a bucket is protected within the Cloud. |
is_external_cloud |
boolean |
Specifies whether a bucket is protected on external Cloud providers. |
is_ontap |
boolean |
Specifies whether a bucket is protected within ONTAP.
protection_status
destination |
is_protected |
boolean |
Specifies whether a bucket is a source and if it is protected within ONTAP and/or an external cloud.
qos_policy
_links |
max_throughput_iops |
integer |
Specifies the maximum throughput in IOPS, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. |
max_throughput_mbps |
integer |
Specifies the maximum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. |
min_throughput_iops |
integer |
Specifies the minimum throughput in IOPS, 0 means none. Setting "min_throughput" is supported on AFF platforms only, unless FabricPool tiering policies are set. This is mutually exclusive with name and UUID during POST and PATCH. |
min_throughput_mbps |
integer |
Specifies the minimum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. |
name |
string |
The QoS policy group name. This is mutually exclusive with UUID and other QoS attributes during POST and PATCH. |
uuid |
string |
The QoS policy group UUID. This is mutually exclusive with name and other QoS attributes during POST and PATCH. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
volume
_links |
name |
string |
The name of the volume. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
