Retrieve the S3 bucket configuration for an SVM
Retrieves the configuration details of an S3 bucket associated with an SVM, giving you insight into its settings and policies.
HTTP method and endpoint
GET /protocols/s3/buckets/{svm.uuid}/{uuid}
Introduced in
ONTAP 9.8
Usage notes
Retrieves the S3 bucket configuration of an SVM. Note that in order to retrieve S3 bucket policy conditions, the 'fields' option should be set to '**'.
Related ONTAP commands
vserver object-store-server bucket show -
vserver object-store-server bucket policy statement show -
vserver object-store-server bucket policy-statement-condition show -
vserver object-store-server bucket lifecycle-management-rule show -
vserver object-store-server bucket cors-rule show
Learn more
uuid |
string |
path |
True |
The unique identifier of the bucket. |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
allowed |
boolean |
If this is set to true, an SVM administrator can manage the S3 service. If it is false, only the cluster administrator can manage the service. This field cannot be specified in a POST method. |
audit_event_selector |
Audit event selector allows you to specify access and permission types to audit. |
comment |
string |
Can contain any additional information about the bucket being created or modified. |
cors |
Cross-origin resource sharing (CORS) specifies an object associated with a bucket. The CORS configuration enables the bucket to service the cross-origin requests. A request might typically come from an origin with a domain that is different to that of the bucket. By configuring a CORS rule, you can define a combination of allowed origins, HTTP headers and methods that a bucket can use to filter out the cross-origin requests that it can service successfully. |
encryption |
is_consistent_etag |
boolean |
Specifies whether the NAS bucket returns a consistent ETag across different S3 requests. |
is_nas_path_mutable |
boolean |
Specifies whether the NAS bucket mapping or association with a NAS volume can change according to the changes in the NAS volume junction-path due to volume operations like mount and unmount and therefore the NAS bucket will have access to any path in a NAS volume that matches the specified nas-path. Or is immutable and therefore the NAS bucket will always have access to the same nas-path that was specified during bucket creation even if the volume junction-path has undergone changes after the bucket creation. |
lifecycle_management |
Lifecycle management is implemented as an object associated with a bucket. It defines rules to be applied against objects within a bucket. These rules are applied in the background and can delete objects. |
logical_used_size |
integer |
Specifies the bucket logical used size up to this point. This field cannot be specified using a POST or PATCH method. |
name |
string |
Specifies the name of the bucket. Bucket name is a string that can only contain the following combination of ASCII-range alphanumeric characters 0-9, a-z, ".", and "-". |
nas_path |
string |
Specifies the NAS path to which the nas bucket corresponds to. |
policy |
A policy is an object associated with a bucket. It defines resource (bucket, folder, or object) permissions. These policies get evaluated when an S3 user makes a request by executing a specific command. The user must be part of the principal (user or group) specified in the policy. Permissions in the policies determine whether the request is allowed or denied. |
protection_status |
Specifies attributes of bucket protection. |
qos_policy |
Specifies "qos_policy.max_throughput_iops" and/or "qos_policy.max_throughput_mbps" or "qos_policy.min_throughput_iops" and/or "qos_policy.min_throughput_mbps". Specifying "min_throughput_iops" or "min_throughput_mbps" is only supported on volumes hosted on a node that is flash optimized. A pre-created QoS policy can also be used by specifying "qos_policy.name" or "qos_policy.uuid" properties. Setting or assigning a QoS policy to a bucket is not supported if its containing volume or SVM already has a QoS policy attached. |
retention |
Specifies the retention mode and default retention period configured on the bucket. |
role |
string |
Specifies the role of the bucket. This field cannot be specified using a POST method. |
size |
integer |
Specifies the bucket size in bytes; ranges from 190MB to 62PB. |
snapshot_policy |
Specifies the bucket snapshot policy. |
svm |
type |
string |
Specifies the bucket type. Valid values are "s3"and "nas". |
uuid |
string |
Specifies the unique identifier of the bucket. |
versioning_state |
string |
Specifies the versioning state of the bucket. Valid values are "disabled", "enabled" or "suspended". Note that the versioning state cannot be modified to 'disabled' from any other state. |
volume |
Specifies the FlexGroup volume name and UUID where the bucket is hosted. |
"audit_event_selector": {
"access": "string",
"permission": "string"
"comment": "S3 bucket.",
"cors": {
"rules": [
"href": "/api/resourcelink"
"allowed_headers": [
"x-amz-request-id"
"allowed_methods": [
"PUT",
"DELETE"
"allowed_origins": [
"http://www.example.com"
"expose_headers": [
"x-amz-date"
"id": "string",
"max_age_seconds": 1024
"lifecycle_management": {
"rules": [
"abort_incomplete_multipart_upload": {
"bucket_name": "bucket1",
"expiration": {
"object_age_days": 100,
"object_expiry_date": "2039-09-22 20:00:00 -0400"
"name": "string",
"non_current_version_expiration": {
"object_filter": {
"prefix": "/logs",
"size_greater_than": 10240,
"size_less_than": 10485760,
"tags": [
"project1=projA",
"project2=projB"
"svm": {
"name": "svm1",
"uuid": "414b29a1-3b26-11e9-bd58-0050568ea055"
"logical_used_size": 0,
"name": "bucket1",
"nas_path": "/",
"policy": {
"statements": [
"actions": [
"GetObject",
"PutObject",
"DeleteObject",
"ListBucket"
"conditions": [
"delimiters": [
"max_keys": [
1000
"operator": "ip_address",
"prefixes": [
"pref"
"source_ips": [
"1.1.1.1",
"1.2.2.0/24"
"usernames": [
"user1"
"effect": "allow",
"principals": [
"user1",
"group/grp1",
"nasgroup/group1"
"resources": [
"bucket1",
"bucket1/*"
"sid": "FullAccessToUser1"
"qos_policy": {
"max_throughput": [
"900KB/s",
"500MB/s",
"120GB/s",
"5000IOPS",
"5000IOPS,500KB/s",
"2500IOPS,100MB/s",
"1000IOPS,25MB/s"
"max_throughput_iops": 10000,
"max_throughput_mbps": 500,
"min_throughput": [
"900KB/s",
"500MB/s",
"120GB/s",
"5000IOPS",
"5000IOPS,500KB/s",
"2500IOPS,100MB/s",
"1000IOPS,25MB/s"
"min_throughput_iops": 2000,
"min_throughput_mbps": 500,
"name": "performance",
"retention": {
"default_period": "P10Y",
"mode": "governance"
"role": "string",
"size": 1677721600,
"snapshot_policy": {
"name": "default-1weekly",
"uuid": "3675af31-431c-12fa-114a-20675afebc12"
"svm": {
"name": "svm1",
"type": "s3",
"use_mirrored_aggregates": true,
"uuid": "414b29a1-3b26-11e9-bd58-0050568ea055",
"versioning_state": "enabled",
"volume": {
"name": "volume1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
aggregates
Aggregate
_links |
name |
string |
uuid |
string |
access |
string |
Specifies read and write access types. |
permission |
string |
Specifies allow and deny permission types. |
rules
Information about the CORS rule of an S3 bucket.
_links |
allowed_headers |
array[string] |
An array of HTTP headers allowed in the cross-origin requests. |
allowed_methods |
array[string] |
An array of HTTP methods allowed in the cross-origin requests. |
allowed_origins |
array[string] |
List of origins from where a cross-origin request is allowed to originate from for the S3 bucket. |
expose_headers |
array[string] |
List of extra headers sent in the response that customers can access from their applications. |
id |
string |
Bucket CORS rule identifier. The length of the name can range from 0 to 256 characters. |
max_age_seconds |
integer |
The time in seconds for your browser to cache the preflight response for the specified resource. |
cors
rules |
array[rules] |
Specifies an object store bucket CORS rule. |
encryption
enabled |
boolean |
Specifies whether encryption is enabled on the bucket. By default, encryption is disabled on a bucket. This field cannot be specified in a POST method. |
Specifies a way to perform abort_incomplete_multipart_upload action on filtered objects within a bucket. It cannot be specified with tags.
_links |
after_initiation_days |
integer |
Number of days of initiation after which uploads can be aborted. |
expiration
Specifies a way to perform expiration action on filtered objects within a bucket.
_links |
expired_object_delete_marker |
boolean |
Cleanup object delete markers. |
object_age_days |
integer |
Number of days since creation after which objects can be deleted. This cannot be used along with object_expiry_date. |
object_expiry_date |
string |
Specific date from when objects can expire. This cannot be used with object_age_days. |
Specifies a way to perform non_current_version_expiration action on filtered objects within a bucket.
_links |
new_non_current_versions |
integer |
Number of latest non-current versions to be retained. |
non_current_days |
integer |
Number of days after which non-current versions can be deleted. |
object_filter
Specifies a way to filter objects within a bucket.
_links |
prefix |
string |
A prefix that is matched against object-names within a bucket. |
size_greater_than |
integer |
Size of the object greater than specified for which the corresponding lifecycle rule is to be applied. |
size_less_than |
integer |
Size of the object smaller than specified for which the corresponding lifecycle rule is to be applied. |
tags |
array[string] |
An array of key-value paired tags of the form |
svm
Specifies the name of the SVM where this bucket exists.
_links |
name |
string |
uuid |
string |
rules
Information about the lifecycle management rule of a bucket.
_links |
abort_incomplete_multipart_upload |
Specifies a way to perform abort_incomplete_multipart_upload action on filtered objects within a bucket. It cannot be specified with tags. |
bucket_name |
string |
enabled |
boolean |
Specifies whether or not the associated rule is enabled. |
expiration |
Specifies a way to perform expiration action on filtered objects within a bucket. |
name |
string |
Bucket lifecycle management rule identifier. The length of the name can range from 0 to 256 characters. |
non_current_version_expiration |
Specifies a way to perform non_current_version_expiration action on filtered objects within a bucket. |
object_filter |
Specifies a way to filter objects within a bucket. |
svm |
Specifies the name of the SVM where this bucket exists. |
uuid |
string |
rules |
array[rules] |
Specifies an object store lifecycle management policy. |
s3_bucket_policy_condition
Information about policy conditions based on various condition operators and condition keys.
delimiters |
array[string] |
An array of delimiters that are compared with the delimiter value specified at the time of execution of an S3-based command, using the condition operator specified. |
max_keys |
array[integer] |
An array of maximum keys that are allowed or denied to be retrieved using an S3 list operation, based on the condition operator specified. |
operator |
string |
Condition operator that is applied to the specified condition key. |
prefixes |
array[string] |
An array of prefixes that are compared with the input prefix value specified at the time of execution of an S3-based command, using the condition operator specified. |
source_ips |
array[string] |
An array of IP address ranges that are compared with the IP address of a source command at the time of execution of an S3-based command, using the condition operator specified. |
usernames |
array[string] |
An array of usernames that a current user in the context is evaluated against using the condition operators. |
s3_bucket_policy_statement
Specifies information about a single access permission.
actions |
array[string] |
conditions |
array[s3_bucket_policy_condition] |
Specifies bucket policy conditions. |
effect |
string |
Specifies whether access is allowed or denied when a user requests the specific action. If access (to allow) is not granted explicitly to a resource, access is implicitly denied. Access can also be denied explicitly to a resource, in order to make sure that a user cannot access it, even if a different policy grants access. |
principals |
array[string] |
resources |
array[string] |
sid |
string |
Specifies the statement identifier used to differentiate between statements. The sid length can range from 1 to 256 characters and can only contain the following combination of characters 0-9, A-Z, and a-z. Special characters are not valid. |
policy
statements |
array[s3_bucket_policy_statement] |
Specifies bucket access policy statement. |
destination
is_cloud |
boolean |
Specifies whether a bucket is protected within the Cloud. This field cannot be specified using a POST method. |
is_external_cloud |
boolean |
Specifies whether a bucket is protected on external Cloud providers. This field cannot be specified using a POST method. |
is_ontap |
boolean |
Specifies whether a bucket is protected within ONTAP. This field cannot be specified using a POST method.
protection_status
destination |
is_protected |
boolean |
Specifies whether a bucket is a source and if it is protected within ONTAP and/or an external cloud. This field cannot be specified using a POST method.
qos_policy
_links |
max_throughput |
string |
Specifies the maximum throughput in Kilobytes per sec, Megabytes per sec or Gigabytes per sec along with or without IOPS. 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when either max_throughput_mbps or max_throughput_iops are set during POST or PATCH. During GET, the returned value is rounded to the largest unit with a value greater than 1. |
max_throughput_iops |
integer |
Specifies the maximum throughput in IOPS, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when max_throughput is set during POST or PATCH. |
max_throughput_mbps |
integer |
Specifies the maximum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when max_throughput is set during POST or PATCH. |
min_throughput |
string |
Specifies the minimum throughput in Kilobytes per sec, Megabytes per sec or Gigabytes per sec along with or without IOPS. 0 means none.Setting "min_throughput" is supported on AFF platforms only, unless FabricPool tiering policies are set. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when either min_throughput_mbps or min_throughput_iops are set during POST or PATCH. During GET, the returned value is rounded to the largest unit with a value greater than 1. |
min_throughput_iops |
integer |
Specifies the minimum throughput in IOPS, 0 means none. Setting "min_throughput" is supported on AFF platforms only, unless FabricPool tiering policies are set. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when min_throughput is set during POST or PATCH. |
min_throughput_mbps |
integer |
Specifies the minimum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.This cannot be set when min_throughput is set during POST or PATCH. |
name |
string |
The QoS policy group name. This is mutually exclusive with UUID and other QoS attributes during POST and PATCH. |
uuid |
string |
The QoS policy group UUID. This is mutually exclusive with name and other QoS attributes during POST and PATCH. |
retention
default_period |
string |
Specifies the default retention period that is applied to objects while committing them to the WORM state without an associated retention period. The retention period can be in years, or days. The retention period value represents a duration and must be specified in the ISO-8601 duration format. A period specified for years and days is represented in the ISO-8601 format as "P |
mode |
string |
The lock mode of the bucket. compliance ‐ A SnapLock Compliance (SLC) bucket provides the highest level of WORM protection and an administrator cannot destroy a compliance bucket if it contains unexpired WORM objects. governance ‐ An administrator can delete a Governance bucket. no_lock ‐ Indicates the bucket does not support object locking. |
snapshot_policy
name |
string |
Specifies the name of the snapshot policy. |
uuid |
string |
Specifies the unique identifier of the snapshot policy. |
svm
_links |
name |
string |
uuid |
string |
volume
_links |
name |
string |
The name of the volume. This field cannot be specified in a PATCH method. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
