REST API reference
Retrieves all s3 lifecycle rules associated with a bucket note that in order to retrieve s3 bucket rule parametes, the fields option should be set to **
learn more
  • [doc /protocols/s3/services/{svmuuid}/buckets/{s3_bucketuuid}/rules](#docs-object-store-protocols_s3_services_{svmuuid}_buckets_{s3_bucketuuid}_rules)
GET /protocols/s3/services/{svm.uuid}/buckets/{s3_bucket.uuid}/rules
Introduced In: 9.13
Retrieves all S3 Lifecycle rules associated with a bucket. Note that in order to retrieve S3 bucket rule parametes, the 'fields' option should be set to '**'.
  • vserver object-store-server bucket lifecycle-management-rule show
non_current_version_expiration.non_current_days
integer
query
False
Filter by non_current_version_expiration.non_current_days
non_current_version_expiration.new_non_current_versions
integer
query
False
Filter by non_current_version_expiration.new_non_current_versions
expiration.object_age_days
integer
query
False
Filter by expiration.object_age_days
expiration.object_expiry_date
string
query
False
Filter by expiration.object_expiry_date
expiration.expired_object_delete_marker
boolean
query
False
Filter by expiration.expired_object_delete_marker
object_filter.prefix
string
query
False
Filter by object_filter.prefix
object_filter.size_less_than
integer
query
False
Filter by object_filter.size_less_than
object_filter.size_greater_than
integer
query
False
Filter by object_filter.size_greater_than
object_filter.tags
string
query
False
Filter by object_filter.tags
abort_incomplete_multipart_upload.after_initiation_days
integer
query
False
Filter by abort_incomplete_multipart_upload.after_initiation_days
enabled
boolean
query
False
Filter by enabled
name
string
query
False
Filter by name
s3_bucket.uuid
string
path
True
The unique identifier of the bucket.
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
collection_links
num_records
integer
Number of records
records
array[s3_bucket_lifecycle_rule]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "abort_incomplete_multipart_upload": {
      "expiration": {
        "object_expiry_date": "string"
      "name": "string",
      "non_current_version_expiration": {
      "object_filter": {
        "prefix": "/logs",
        "size_greater_than": 10485760,
        "size_less_than": 10240,
        "tags": [
          "project1=projA",
          "project2=projB"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
Specifies a way to perform abort_incomplete_multipart_upload action on filtered objects within a bucket.
_links
_links
integer
Number of days of initiation after which uploads can be aborted.
expiration
Specifies a way to perform expiration action on filtered objects within a bucket.
_links
_links
boolean
Cleanup object delete markers.
object_age_days
integer
Number of days since creation after which objects can be deleted.
object_expiry_date
string
Specific date from when objects can expire.
Specifies a way to perform non_current_version_expiration action on filtered objects within a bucket.
_links
_links
integer
Number of latest non-current versions to be retained.
non_current_days
integer
Number of days after which non-current versions can be deleted.
object_filter
Specifies a way to filter objects within a bucket.
_links
_links
prefix
string
A prefix that is matched against object-names within a bucket.
size_greater_than
integer
Size of the object greater than specified for which the corresponding lifecycle rule is to be applied.
size_less_than
integer
Size of the object smaller than specified for which the corresponding lifecycle rule is to be applied.
tags
array[string]
An array of key-value paired tags of the form or <tag=value>.
Information about the lifecycle management rule of a bucket.
_links
_links
enabled
boolean
Specifies whether or not the associated rule is enabled.
expiration
expiration
name
string
Bucket lifecycle management rule identifier.
object_filter
object_filter
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
