REST API reference
Retrieve S3 lifecycle rules for a bucket
Retrieves all S3 Lifecycle rules associated with a bucket, which helps you manage the lifecycle of objects within the bucket effectively.
HTTP method and endpoint
GET /protocols/s3/services/{svm.uuid}/buckets/{s3_bucket.uuid}/rules
Introduced in
ONTAP 9.13
Usage notes
Note that in order to retrieve S3 bucket rule parameters, the 'fields' option should be set to '**'.
  • vserver object-store-server bucket lifecycle-management-rule show
uuid
string
query
False
Filter by uuid
  • Introduced in: 9.14
name
string
query
False
Filter by name
  • maxLength: 256
  • minLength: 0
bucket_name
string
query
False
Filter by bucket_name
  • maxLength: 63
  • minLength: 3
non_current_version_expiration.new_non_current_versions
integer
query
False
Filter by non_current_version_expiration.new_non_current_versions
non_current_version_expiration.non_current_days
integer
query
False
Filter by non_current_version_expiration.non_current_days
expiration.object_age_days
integer
query
False
Filter by expiration.object_age_days
expiration.expired_object_delete_marker
boolean
query
False
Filter by expiration.expired_object_delete_marker
expiration.object_expiry_date
string
query
False
Filter by expiration.object_expiry_date
object_filter.tags
string
query
False
Filter by object_filter.tags
object_filter.prefix
string
query
False
Filter by object_filter.prefix
object_filter.size_greater_than
integer
query
False
Filter by object_filter.size_greater_than
object_filter.size_less_than
integer
query
False
Filter by object_filter.size_less_than
enabled
boolean
query
False
Filter by enabled
abort_incomplete_multipart_upload.after_initiation_days
integer
query
False
Filter by abort_incomplete_multipart_upload.after_initiation_days
svm.name
string
query
False
Filter by svm.name
s3_bucket.uuid
string
path
True
The unique identifier of the bucket.
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
collection_links
num_records
integer
Number of records
records
array[s3_bucket_lifecycle_rule]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "abort_incomplete_multipart_upload": {
      "bucket_name": "bucket1",
      "expiration": {
        "object_age_days": 100,
        "object_expiry_date": "2039-09-22 20:00:00 -0400"
      "name": "string",
      "non_current_version_expiration": {
      "object_filter": {
        "prefix": "/logs",
        "size_greater_than": 10240,
        "size_less_than": 10485760,
        "tags": [
          "project1=projA",
          "project2=projB"
      "svm": {
        "name": "svm1",
      "uuid": "414b29a1-3b26-11e9-bd58-0050568ea055"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
Specifies a way to perform abort_incomplete_multipart_upload action on filtered objects within a bucket. It cannot be specified with tags.
_links
_links
integer
Number of days of initiation after which uploads can be aborted.
expiration
Specifies a way to perform expiration action on filtered objects within a bucket.
_links
_links
boolean
Cleanup object delete markers.
object_age_days
integer
Number of days since creation after which objects can be deleted. This cannot be used along with object_expiry_date.
object_expiry_date
string
Specific date from when objects can expire. This cannot be used with object_age_days.
Specifies a way to perform non_current_version_expiration action on filtered objects within a bucket.
_links
_links
integer
Number of latest non-current versions to be retained.
non_current_days
integer
Number of days after which non-current versions can be deleted.
object_filter
Specifies a way to filter objects within a bucket.
_links
_links
prefix
string
A prefix that is matched against object-names within a bucket.
size_greater_than
integer
Size of the object greater than specified for which the corresponding lifecycle rule is to be applied.
size_less_than
integer
Size of the object smaller than specified for which the corresponding lifecycle rule is to be applied.
tags
array[string]
An array of key-value paired tags of the form or <tag=value>.
svm
Specifies the name of the SVM where this bucket exists.
_links
_links
name
string
uuid
string
Information about the lifecycle management rule of a bucket.
_links
_links
bucket_name
string
Specifies the name of the bucket. Bucket name is a string that can only contain the following combination of ASCII-range alphanumeric characters 0-9, a-z, ".", and "-".
enabled
boolean
Specifies whether or not the associated rule is enabled.
expiration
expiration
name
string
Bucket lifecycle management rule identifier. The length of the name can range from 0 to 256 characters.
object_filter
object_filter
svm
svm
uuid
string
Specifies the unique identifier of the bucket.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
