Retrieve S3 lifecycle rules for a bucket
Retrieves S3 lifecycle rules for a bucket to understand its associated management policies and configurations. This helps you ensure that the bucket's data lifecycle aligns with your storage policies or regulatory requirements.
HTTP method and endpoint
GET /protocols/s3/services/{svm.uuid}/buckets/{s3_bucket.uuid}/rules
Introduced in
ONTAP 9.13
Usage notes
Retrieves all S3 Lifecycle rules associated with a bucket. Note that in order to retrieve S3 bucket rule parameters, the 'fields' option should be set to '**'.
Related ONTAP commands
vserver object-store-server bucket lifecycle-management-rule show
expiration.expired_object_delete_marker |
boolean |
query |
False |
Filter by expiration.expired_object_delete_marker |
expiration.object_age_days |
integer |
query |
False |
Filter by expiration.object_age_days |
expiration.object_expiry_date |
string |
query |
False |
Filter by expiration.object_expiry_date |
object_filter.size_greater_than |
integer |
query |
False |
Filter by object_filter.size_greater_than |
object_filter.tags |
string |
query |
False |
Filter by object_filter.tags |
object_filter.prefix |
string |
query |
False |
Filter by object_filter.prefix |
object_filter.size_less_than |
integer |
query |
False |
Filter by object_filter.size_less_than |
enabled |
boolean |
query |
False |
Filter by enabled |
bucket_name |
string |
query |
False |
Filter by bucket_name
name |
string |
query |
False |
Filter by name
svm.name |
string |
query |
False |
Filter by svm.name
abort_incomplete_multipart_upload.after_initiation_days |
integer |
query |
False |
Filter by abort_incomplete_multipart_upload.after_initiation_days |
uuid |
string |
query |
False |
Filter by uuid
non_current_version_expiration.non_current_days |
integer |
query |
False |
Filter by non_current_version_expiration.non_current_days |
non_current_version_expiration.new_non_current_versions |
integer |
query |
False |
Filter by non_current_version_expiration.new_non_current_versions |
s3_bucket.uuid |
string |
path |
True |
The unique identifier of the bucket. |
svm.uuid |
string |
path |
True |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[s3_bucket_lifecycle_rule] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"abort_incomplete_multipart_upload": {
"bucket_name": "bucket1",
"expiration": {
"object_age_days": 100,
"object_expiry_date": "2039-09-23 00:00:00 +0000"
"name": "string",
"non_current_version_expiration": {
"object_filter": {
"prefix": "/logs",
"size_greater_than": 10240,
"size_less_than": 10485760,
"tags": [
"project1=projA",
"project2=projB"
"svm": {
"name": "svm1",
"uuid": "414b29a1-3b26-11e9-bd58-0050568ea055"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
collection_links
next |
self |
_links
self |
Specifies a way to perform abort_incomplete_multipart_upload action on filtered objects within a bucket. It cannot be specified with tags.
_links |
integer |
Number of days of initiation after which uploads can be aborted. |
expiration
Specifies a way to perform expiration action on filtered objects within a bucket.
_links |
boolean |
Cleanup object delete markers. |
object_age_days |
integer |
Number of days since creation after which objects can be deleted. This cannot be used along with object_expiry_date. |
string |
Specific date from when objects can expire. This cannot be used with object_age_days. |
Specifies a way to perform non_current_version_expiration action on filtered objects within a bucket.
_links |
integer |
Number of latest non-current versions to be retained. |
non_current_days |
integer |
Number of days after which non-current versions can be deleted. |
object_filter
Specifies a way to filter objects within a bucket.
_links |
prefix |
string |
A prefix that is matched against object-names within a bucket. |
size_greater_than |
integer |
Size of the object greater than specified for which the corresponding lifecycle rule is to be applied. |
size_less_than |
integer |
Size of the object smaller than specified for which the corresponding lifecycle rule is to be applied. |
tags |
array[string] |
An array of key-value paired tags of the form |
svm
Specifies the name of the SVM where this bucket exists.
_links |
name |
string |
uuid |
string |
Information about the lifecycle management rule of a bucket.
_links |
abort_incomplete_multipart_upload |
Specifies a way to perform abort_incomplete_multipart_upload action on filtered objects within a bucket. It cannot be specified with tags. |
bucket_name |
string |
Specifies the name of the bucket. Bucket name is a string that can only contain the following combination of ASCII-range alphanumeric characters 0-9, a-z, ".", and "-". |
enabled |
boolean |
Specifies whether or not the associated rule is enabled. |
expiration |
Specifies a way to perform expiration action on filtered objects within a bucket. |
name |
string |
Bucket lifecycle management rule identifier. The length of the name can range from 0 to 256 characters. |
non_current_version_expiration |
Specifies a way to perform non_current_version_expiration action on filtered objects within a bucket. |
object_filter |
Specifies a way to filter objects within a bucket. |
svm |
Specifies the name of the SVM where this bucket exists. |
uuid |
string |
Specifies the unique identifier of the bucket. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
