REST API reference
Retrieve the SVM configuration for an S3 user
Retrieves the SVM configuration for an S3 user to understand and manage the user's storage virtual machine settings.
HTTP method and endpoint
GET /protocols/s3/services/{svm.uuid}/users
Introduced in
ONTAP 9.7
Usage notes
Retrieves the S3 user's SVM configuration.
  • vserver object-store-server user show
svm.name
string
query
False
Filter by svm.name
access_key
string
query
False
Filter by access_key
name
string
query
False
Filter by name
  • maxLength: 64
  • minLength: 1
comment
string
query
False
Filter by comment
  • maxLength: 256
  • minLength: 0
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
collection_links
num_records
integer
Number of records
records
array[s3_user]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "access_key": "Pz3SB54G2B_6dsXQPrA5HrTPcf478qoAW6_Xx6qyqZ948AgZ_7YfCf_9nO87YoZmskxx3cq41U2JAH2M3_fs321B4rkzS3a_oC5_8u7D8j_45N8OsBCBPWGD_1d_ccfq",
      "comment": "S3 user",
      "name": "user-1",
      "svm": {
        "name": "svm1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
svm
_links
_links
name
string
The name of the SVM.
uuid
string
s3_user
This is a container of S3 users.
access_key
string
Specifies the access key for the user.
comment
string
Can contain any additional information about the user being created or modified.
name
string
Specifies the name of the user. A user name length can range from 1 to 64 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-".
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
