REST API reference
Retrieve the SVM configuration for an S3 user
Retrieves the SVM configuration for an S3 user to understand the storage virtual machine settings associated with that user. This information is essential when managing user-specific configurations in S3 protocols.
HTTP method and endpoint
GET /protocols/s3/services/{svm.uuid}/users
Introduced in
ONTAP 9.7
Usage notes
Retrieves the S3 user's SVM configuration.
  • vserver object-store-server user show
name
string
query
False
Filter by name
  • maxLength: 64
  • minLength: 1
svm.name
string
query
False
Filter by svm.name
access_key
string
query
False
Filter by access_key
keys.id
integer
query
False
Filter by keys.id
  • Introduced in: 9.19
  • Max value: 2
  • Min value: 1
keys.access_key
string
query
False
Filter by keys.access_key
keys.expiry_time
string
query
False
Filter by keys.expiry_time
keys.time_to_live
string
query
False
Filter by keys.time_to_live
comment
string
query
False
Filter by comment
  • maxLength: 256
  • minLength: 0
key_expiry_time
string
query
False
Filter by key_expiry_time
  • Introduced in: 9.14
key_time_to_live
string
query
False
Filter by key_time_to_live
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Max value: 120
  • Min value: 0
  • Default value: 15
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
collection_links
num_records
integer
Number of records
records
array[s3_user]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "access_key": "<AWS-ACCESS-KEY-ID>",
      "comment": "S3 user",
      "key_expiry_time": "2024-01-01 00:00:00 +0000",
      "key_id": 1,
      "key_time_to_live": "PT6H3M",
      "keys": [
          "expiry_time": "2024-01-01 00:00:00 +0000",
          "id": 1,
          "time_to_live": "PT6H3M"
      "name": "user-1",
      "svm": {
        "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
keys
Specifies a key associated with an S3 user. At most only two keys can be associated with a user.
access_key
string
Specifies the access key for the user.
expiry_time
string
Specifies the date and time after which keys expire and are no longer valid.
id
integer
Specifies an S3 user key identifier. Each user can only have a maximum of two keys. The key_id can either be '1' or '2'.
time_to_live
string
Indicates the time period from when this parameter is specified:
  • when creating or modifying a user or
  • when the user keys were last regenerated, after which the user keys expire and are no longer valid.
  • Valid format is: 'PnDTnHnMnS|PnW'. For example, P2DT6H3M10S specifies a time period of 2 days, 6 hours, 3 minutes, and 10 seconds.
  • If the value specified is '0' seconds, then the keys do not expire.
self
svm
_links
_links
name
string
uuid
string
s3_user
This is a container of S3 users.
access_key
string
comment
string
Can contain any additional information about the user being created or modified.
key_expiry_time
string
key_id
integer
Specifies the identifier of an S3 user key that needs to be generated or deleted. The key_id can either be '1' or '2'.
key_time_to_live
string
  • If the value specified is '0' seconds, then the keys won't expire.
keys
array[keys]
Specifies the keys associated with an S3 User.
name
string
Specifies the name of the user. A user name length can range from 1 to 64 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-".
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
