Retrieve the SVM configuration for an S3 user
Retrieves the SVM configuration for an S3 user to understand the user's setup and manage their access to S3 resources effectively.
HTTP method and endpoint
GET /protocols/s3/services/{svm.uuid}/users
Introduced in
ONTAP 9.7
Usage notes
Retrieves the S3 user's SVM configuration.
Related ONTAP commands
vserver object-store-server user show
Learn more
name |
string |
query |
False |
Filter by name
svm.name |
string |
query |
False |
Filter by svm.name |
access_key |
string |
query |
False |
Filter by access_key |
comment |
string |
query |
False |
Filter by comment
key_time_to_live |
string |
query |
False |
Filter by key_time_to_live
key_expiry_time |
string |
query |
False |
Filter by key_expiry_time
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[s3_user] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"access_key": "HJAKU28M3SXTE2UXUACV",
"comment": "S3 user",
"key_expiry_time": "2023-12-31 19:00:00 -0500",
"key_time_to_live": "PT6H3M",
"name": "user-1",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
collection_links
next |
self |
_links
self |
svm
_links |
name |
string |
uuid |
string |
s3_user
This is a container of S3 users.
access_key |
string |
Specifies the access key for the user. |
comment |
string |
Can contain any additional information about the user being created or modified. |
key_expiry_time |
string |
Specifies the date and time after which keys expire and are no longer valid. |
key_time_to_live |
string |
Indicates the time period from when this parameter is specified:
name |
string |
Specifies the name of the user. A user name length can range from 1 to 64 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-". |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
