Retrieve an initiator group
Retrieves information about an initiator group, helping you understand its configuration and associated properties within your ONTAP environment.
HTTP method and endpoint
GET /protocols/san/igroups/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Retrieves an initiator group.
Expensive properties
There is an added computational cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
igroups.* -
lun_maps.* -
parent_igroups.* -
connectivity_tracking.*
Related ONTAP commands
lun igroup show -
lun mapping show
Learn more
uuid |
string |
path |
True |
The unique identifier of the initiator group. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
comment |
string |
A comment available for use by the administrator. Valid in POST and PATCH. |
connectivity_tracking |
An overview of the connections to ONTAP by the initiators in this group.
delete_on_unmap |
boolean |
An option that causes the initiator group to be deleted when the last LUN map associated with it is deleted. Optional in POST and PATCH. This property defaults to false when the initiator group is created. |
igroups |
array[igroup_child] |
The initiator groups that are members of the group. Optional in POST. This property is mutually exclusive with the initiators property during POST. This array contains only the direct children of the initiator group. If the member initiator groups have further nested initiator groups, those are reported in the Zero or more nested initiator groups can be supplied when the initiator group is created. The initiator group will act as if it contains the aggregatation of all initiators in any nested initiator groups. After creation, nested initiator groups can be added or removed from the initiator group using the |
initiators |
array[initiators] |
The initiators that are members of the group or any group nested below this group. Optional in POST. This property is mutually exclusive with the igroups property during POST. During GET, this array contains initiators that are members of this group or any nested initiator groups below this group. When initiators of nested groups are returned, they include links to the initiator group that directly contains the initiator. Zero or more initiators can be supplied when the initiator group is created. After creation, initiators can be added or removed from the initiator group using the |
lun_maps |
array[lun_maps] |
All LUN maps with which the initiator is associated. If the requested igroup is part of a remote, non-local, MetroCluster SVM, the LUN maps are not retrieved. There is an added computational cost to retrieving property values for |
name |
string |
The name of the initiator group. Required in POST; optional in PATCH. |
os_type |
string |
The host operating system of the initiator group. All initiators in the group should be hosts of the same operating system. Required in POST; optional in PATCH. |
parent_igroups |
array[] |
The initiator groups that contain this initiator group as as member. |
portset |
The portset to which the initiator group is bound. Binding the initiator group to a portset restricts the initiators of the group to accessing mapped LUNs only through network interfaces in the portset. Optional in POST and PATCH. PATCH |
protocol |
string |
The protocols supported by the initiator group. This restricts the type of initiators that can be added to the initiator group. Optional in POST; if not supplied, this defaults to mixed. The protocol of an initiator group cannot be changed after creation of the group. |
supports_igroups |
boolean |
An initiator group may contain either initiators or other initiator groups, but not both simultaneously. This property is true when initiator groups can be added to this initiator group. The |
svm |
target |
Properties of the SCSI target to which the initiator group provides access. |
uuid |
string |
"href": "/api/resourcelink"
"comment": "string",
"connectivity_tracking": {
"alerts": [
"summary": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
"connection_state": "string",
"required_nodes": [
"name": "node1",
"igroups": [
"name": "igroup1",
"initiators": [
"igroup": {
"name": "igroup1",
"name": "iqn.1998-01.com.corp.iscsi:name1"
"lun_maps": [
"logical_unit_number": 0,
"lun": {
"name": "lun1",
"node": {
"name": "node1",
"name": "igroup1",
"os_type": "string",
"portset": {
"name": "portset1",
"protocol": "string",
"svm": {
"name": "svm1",
"target": {
"firmware_revision": "9111",
"product_id": "LUN C-Mode",
"vendor_id": "NETAPP"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5374852 |
The initiator group does not exist. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
code |
string |
Argument code |
message |
string |
Message argument |
summary
A user friendly message describing the connection state of the initiator group.
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
alerts
summary |
A user friendly message describing the connection state of the initiator group. |
required_nodes
_links |
name |
string |
uuid |
string |
alerts |
array[alerts] |
connection_state |
string |
Connection state. |
required_nodes |
array[required_nodes] |
Nodes to which the initiators in this group should be connected to ensure reliable service. This is the collection of any node hosting a LUN mapped to this igroup as well as the HA partners of those nodes. |
igroup_child
_links |
comment |
string |
A comment available for use by the administrator. |
igroups |
array[] |
Further nested initiator groups. |
name |
string |
The name of the initiator group. |
uuid |
string |
A link to the initiator with connectivity information relevant to its membership of this initiator group.
href |
string |
self
A link to the initiator where mutations can be made. If the initiator is inherited from a nested initiator group, the link refers to the initiator in the nested initiator group. In this case, mutations of the initiator will be applied to all initiator groups referencing the same nested initiator group.
href |
string |
_links
A link to the initiator with connectivity information relevant to its membership of this initiator group. |
self |
A link to the initiator where mutations can be made. If the initiator is inherited from a nested initiator group, the link refers to the initiator in the nested initiator group. In this case, mutations of the initiator will be applied to all initiator groups referencing the same nested initiator group. |
Overview of the initiator's connections to ONTAP.
connection_state |
string |
Connection state. |
igroup
The initiator group that directly owns the initiator, which is where modification of the initiator is supported. This property will only be populated when the initiator is a member of a nested initiator group.
_links |
name |
string |
uuid |
string |
initiators
_links |
comment |
string |
igroup |
The initiator group that directly owns the initiator, which is where modification of the initiator is supported. This property will only be populated when the initiator is a member of a nested initiator group. |
name |
string |
The FC WWPN, iSCSI IQN, or iSCSI EUI that identifies the host initiator. Valid in POST only and not allowed when the An FC WWPN consists of 16 hexadecimal digits grouped as 8 pairs separated by colons. The format for an iSCSI IQN is iqn.yyyy-mm.reverse_domain_name:any. The iSCSI EUI format consists of the eui. prefix followed by 16 hexadecimal characters. |
node
_links |
name |
string |
uuid |
string |
lun
The LUN to which the initiator group is mapped.
_links |
name |
string |
The name of the LUN. |
node |
uuid |
string |
The unique identifier of the LUN. |
lun_maps
A LUN map with which the initiator group is associated.
_links |
logical_unit_number |
integer |
The logical unit number assigned to the LUN for initiators in the initiator group. |
lun |
The LUN to which the initiator group is mapped. |
portset
Optional in POST and PATCH. PATCH portset.name to an empty string ("") to unbind a portset from the initiator group.
_links |
name |
string |
The name of the portset. |
uuid |
string |
The unique identifier of the portset. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
target
firmware_revision |
string |
The firmware revision of the SCSI target specific to the OS type of the initiator group. |
product_id |
string |
The product ID of the SCSI target. |
vendor_id |
string |
The vendor ID of the SCSI target. |
error
arguments |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
