REST API reference
Retrieve an initiator group
Retrieves an initiator group, providing details about its configuration and attributes in your storage setup.
HTTP method and endpoint
GET /protocols/san/igroups/{uuid}
Introduced in
ONTAP 9.6
Expensive properties
There is an added computational cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
  • connectivity_tracking.*
  • igroups.*
  • lun_maps.*
  • parent_igroups.*
  • lun igroup show
  • lun mapping show
uuid
string
path
True
The unique identifier of the initiator group.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
comment
string
A comment available for use by the administrator. Valid in POST and PATCH.
An overview of the connections to ONTAP by the initiators in this group.
  • readOnly: 1
  • Introduced in: 9.11
delete_on_unmap
boolean
An option that causes the initiator group to be deleted when the last LUN map associated with it is deleted. Optional in POST and PATCH. This property defaults to false when the initiator group is created.
igroups
array[igroup_child]
The existing initiator groups that are members of the group. Optional in POST.
This property is mutually exclusive with the initiators property during POST.
This array contains only the direct children of the initiator group. If the member initiator groups have further nested initiator groups, those are reported in the igroups property of the child initiator group.
Zero or more nested initiator groups can be supplied when the initiator group is created. The initiator group will act as if it contains the aggregation of all initiators in any nested initiator groups.
After creation, nested initiator groups can be added or removed from the initiator group using the /protocols/san/igroups/{igroup.uuid}/igroups endpoint. See POST /protocols/san/igroups/{igroup.uuid}/igroups and DELETE /protocols/san/igroups/{igroup.uuid}/igroups/{uuid} for more details.
initiators
array[initiators]
The initiators that are members of the group or any group nested below this group. Optional in POST.
This property is mutually exclusive with the igroups property during POST.
During GET, this array contains initiators that are members of this group or any nested initiator groups below this group. When initiators of nested groups are returned, they include links to the initiator group that directly contains the initiator.
Zero or more initiators can be supplied when the initiator group is created. After creation, initiators can be added or removed from the initiator group using the /protocols/san/igroups/{igroup.uuid}/initiators endpoint. See POST /protocols/san/igroups/{igroup.uuid}/initiators and DELETE /protocols/san/igroups/{igroup.uuid}/initiators/{name} for more details.
lun_maps
array[lun_maps]
All LUN maps with which the initiator is associated.
If the requested igroup is part of a remote, non-local, MetroCluster SVM, the LUN maps are not retrieved.
There is an added computational cost to retrieving property values for lun_maps. They are not populated for a GET request unless explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
name
string
The name of the initiator group. Required in POST; optional in PATCH.
os_type
string
The host operating system of the initiator group. All initiators in the group should be hosts of the same operating system. Required in POST; optional in PATCH.
parent_igroups
array[igroup_parent]
The initiator groups that contain this initiator group as a member.
portset
portset
The portset to which the initiator group is bound. Binding the initiator group to a portset restricts the initiators of the group to accessing mapped LUNs only through network interfaces in the portset.
In a nested initiator group hierarchy, only a portset bound to the initiator group at the same level at which it is mapped, applies; portsets bound to parent or child initiator groups are ignored.
Optional in POST and PATCH. To unbind a portset from the initiator group, PATCH the portset object to null, or PATCH portset.name to an empty string ("").
protocol
string
The protocols supported by the initiator group. This restricts the type of initiators that can be added to the initiator group. Optional in POST; if not supplied, this defaults to mixed.
The protocol of an initiator group cannot be changed after creation of the group.
replication
replication
Properties related to initiator group replication.
supports_igroups
boolean
An initiator group may contain either initiators or other initiator groups, but not both simultaneously. This property is true when initiator groups can be added to this initiator group. The initiators.name property cannot be used to determine this via a query because it reports initiators inherited from nested igroups.
svm
svm
target
target
Properties of the SCSI target to which the initiator group provides access.
uuid
string
      "href": "/api/resourcelink"
  "comment": "string",
  "connectivity_tracking": {
    "alerts": [
        "summary": {
          "arguments": [
              "code": "string",
              "message": "string"
          "code": "4",
          "message": "entry doesn't exist"
    "connection_state": "string",
    "required_nodes": [
        "name": "node1",
  "igroups": [
      "igroups": [
        null
      "name": "igroup1",
  "initiators": [
      "igroup": {
        "name": "igroup1",
      "name": "iqn.1998-01.com.corp.iscsi:name1",
      "proximity": {
        "peer_svms": [
            "name": "peer1",
            "uuid": "4204cf77-4c82-9bdb-5644-b5a841c097a9"
  "lun_maps": [
      "logical_unit_number": 0,
      "lun": {
        "name": "lun1",
        "node": {
          "name": "node1",
  "name": "igroup1",
  "os_type": "string",
  "parent_igroups": [
      "name": "igroup1",
      "parent_igroups": [
        null
  "portset": {
    "name": "portset1",
  "protocol": "string",
  "replication": {
    "error": {
      "igroup": {
        "name": "igroup1",
      "summary": {
        "arguments": [
            "code": "string",
            "message": "string"
        "code": "4",
    "peer_svm": {
      "name": "peer1",
    "state": "string"
  "svm": {
    "name": "svm1",
  "target": {
    "firmware_revision": "9111",
    "product_id": "LUN C-Mode",
    "vendor_id": "NETAPP"
Status: Default
ONTAP Error Response Codes
Error Code Description
5374852
The initiator group does not exist.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
code
string
Argument code
message
string
Message argument
summary
A user friendly message describing the connection state of the initiator group.
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
alerts
summary
summary
required_nodes
_links
_links
name
string
uuid
string
alerts
array[alerts]
connection_state
string
Connection state.
required_nodes
array[required_nodes]
Nodes to which the initiators in this group should be connected to ensure reliable service. This is the collection of any node hosting a LUN mapped to this igroup as well as the HA partners of those nodes.
igroup_child
_links
_links
comment
string
igroups
array[igroup_child]
Further nested initiator groups.
name
string
uuid
string
A link to the initiator with connectivity information relevant to its membership of this initiator group.
string
self
A link to the initiator where mutations can be made. If the initiator is inherited from a nested initiator group, the link refers to the initiator in the nested initiator group. In this case, mutations of the initiator will be applied to all initiator groups referencing the same nested initiator group.
string
self
self
Overview of the initiator's connections to ONTAP.
connection_state
string
Connection state.
igroup
The initiator group that directly owns the initiator, which is where modification of the initiator is supported. This property will only be populated when the initiator is a member of a nested initiator group.
_links
_links
name
string
uuid
string
peer_svms
A reference to an SVM peer relationship.
_links
_links
name
string
The local name of the peer SVM. This name is unique among all local and peer SVMs.
uuid
string
The unique identifier of the SVM peer relationship. This is the UUID of the relationship, not the UUID of the peer SVM itself.
proximity
Properties that define to what SVMs the initiator is proximal. This information is used to properly report active optimized and active non-optimized network paths via ALUA. If no configuration has been specified for an initiator, the sub-object will not be present in GET.
These properties can be set via initiator group POST and PATCH and apply to all instances of the initiator in all initiator groups in the SVM and its peers. The proximity sub-object for an initiator is set in POST and PATCH in its entirety and replaces any previously set proximity for the initiator within the SVM for the initiator within the SVM. The local_svm property must always be set to true or false when setting the proximity property. To clear any previously set proximity, POST or PATCH the proximity object to null.
local_svm
boolean
A boolean that indicates if the initiator is proximal to the SVM of the containing initiator group. This is required for any POST or PATCH that includes the proximity sub-object.
peer_svms
array[peer_svms]
An array of remote peer SVMs to which the initiator is proximal.
initiators
_links
_links
comment
string
  • readOnly: 1
igroup
igroup
name
string
The FC WWPN, iSCSI IQN, or iSCSI EUI that identifies the host initiator. Valid in POST only and not allowed when the records property is used.
An FC WWPN consists of 16 hexadecimal digits grouped as 8 pairs separated by colons. The format for an iSCSI IQN is iqn.yyyy-mm.reverse_domain_name:any. The iSCSI EUI format consists of the eui. prefix followed by 16 hexadecimal characters.
proximity
proximity
node
_links
_links
name
string
uuid
string
lun
The LUN to which the initiator group is mapped.
_links
_links
name
string
The name of the LUN.
node
node
uuid
string
The unique identifier of the LUN.
lun_maps
A LUN map with which the initiator group is associated.
_links
_links
logical_unit_number
integer
The logical unit number assigned to the LUN for initiators in the initiator group.
lun
lun
igroup_parent
_links
_links
comment
string
name
string
parent_igroups
uuid
string
portset
_links
_links
name
string
The name of the portset.
uuid
string
The unique identifier of the portset.
igroup
local_svm
boolean
Indicates whether the reported igroup is on the local SVM or the peer SVM. When deleting a replicated igroup, the local copy is deleted first and then the peer copy is deleted. If the error is encountered between these two operations and only the peer igroup remains, the peer igroup is reported and the problem might need to be corrected on the peer cluster.
name
string
uuid
string
summary
A user friendly message describing the error.
arguments
Message arguments
code
string
Error code
message
string
Error message
error
Information about asynchronous errors encountered while replicating this igroup. Igroups within a peering relationship are replicated in the same stream, so the error reported here might be related to this igroup or a prior replicated igroup that is now blocking the replication of this igroup. Both the error information and the igroup encountering the error are reported. If the error is configuration related, it can be corrected on the referenced igroup. The replication is retried using exponential backoff up to a maximum of one retry every 5 minutes. Every operation on the same stream triggers an immediate retry and restarts the exponential backoff starting with a 1 second delay. If the error is system related, the retries should correct the error when the system enters a healthy state.
igroup
igroup
summary
summary
peer_svm
The peered SVM to which the initiator group should be replicated. Optional in POST and PATCH. To clear any previously set replication peer, PATCH the replication.peer_svm object to null.
_links
_links
name
string
uuid
string
replication
error
error
peer_svm
peer_svm
state
string
The state of the replication queue associated with this igroup. If this igroup is not in the replication queue, the state is reported as ok. If this igroup is in the replication queue, but no errors have been encountered, the state is reported as replicating. If this igroup is in the replication queue and the queue is blocked by an error, the state is reported as error. When in the error state, additional context is provided by the replication.error property.
svm
_links
_links
name
string
uuid
string
target
firmware_revision
string
The firmware revision of the SCSI target specific to the OS type of the initiator group.
product_id
string
The product ID of the SCSI target.
vendor_id
string
The vendor ID of the SCSI target.
returned_error
arguments
Message arguments
code
string
Error code
message
string
Error message
target
string
