REST API reference
Retrieve currently used resource tags
Accesses the currently used resource tags, which can help you understand the tagging structure applied to resources.
HTTP method and endpoint
GET /resource-tags
Introduced in
ONTAP 9.13
Usage notes
Retrieves the tags currently being used for resources in the API.
num_resources
integer
query
False
Filter by num_resources
  • Min value: 1
value
string
query
False
Filter by value
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Min value: 0
  • Default value: 15
  • Max value: 120
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[resource_tag]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "value": "team:accounting"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
resource_tag
A resource tag is a way to group resources in the API together for identification or tracking purposes.
num_resources
integer
The number of resources that are currently using this tag.
value
string
A key:value formatted string representing the tag's name.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
