REST API reference
Retrieve the tags currently used for resources
Retrieves the tags that are currently in use for various resources. This helps you manage and organize your resources more effectively.
HTTP method and endpoint
GET /resource-tags
Introduced in
ONTAP 9.13
Usage notes
Retrieves the tags currently being used for resources in the API.
num_resources
integer
query
False
Filter by num_resources
  • Min value: 1
value
string
query
False
Filter by value
  • maxLength: 200
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Min value: 0
  • Default value: 15
  • Max value: 120
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[resource_tag]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "value": "team:accounting"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
resource_tag
A resource tag is a way to group resources in the API together for identification or tracking purposes.
num_resources
integer
The number of resources that are currently using this tag.
value
string
A key:value formatted string representing the tag's name.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
