Retrieve the tags currently used for resources
GET /resource-tags
Introduced In: 9.13
Retrieves the tags currently being used for resources in the API.
num_resources |
integer |
query |
False |
Filter by num_resources
value |
string |
query |
False |
Filter by value
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[resource_tag] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"value": "team:accounting"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
resource_tag
A resource tag is a way to group resources in the API together for identification or tracking purposes.
num_resources |
integer |
The number of resources that are currently using this tag. |
value |
string |
A key:value formatted string representing the tag's name. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
