REST API reference
Retrieves svm information configured as an active directory domain-tunnel
learn more
  • [doc /security/authentication/cluster/ad-proxy](#docs-security-security_authentication_cluster_ad-proxy)
  • [doc /security/accounts](#docs-security-security_accounts)
GET /security/authentication/cluster/ad-proxy
Introduced In: 9.7
Retrieves SVM information configured as an Active Directory domain-tunnel.
  • security login domain-tunnel show
Status: 200, Ok
Name Type Description
_links
_links
svm
svm
      "href": "/api/resourcelink"
  "svm": {
    "name": "svm1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
svm
_links
_links
name
string
The name of the SVM.
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
