Retrieve SVM information configured as an Active Directory domain-tunnel
GET /security/authentication/cluster/ad-proxy
Introduced In: 9.7
Retrieves SVM information configured as an Active Directory domain-tunnel.
Related ONTAP commands
security login domain-tunnel show
Status: 200, Ok
| Name | Type | Description |
_links |
svm |
"href": "/api/resourcelink"
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
svm
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
