REST API reference
Retrieve SVM information configured as an Active Directory domain-tunnel
Retrieves information about SVMs configured as Active Directory domain-tunnels, which helps you manage and verify the domain-tunnel configurations within your network.
HTTP method and endpoint
GET /security/authentication/cluster/ad-proxy
Introduced in
ONTAP 9.7
Usage notes
Retrieves SVM information configured as an Active Directory domain-tunnel.
  • security login domain-tunnel show
Status: 200, Ok
Name Type Description
_links
_links
svm
svm
      "href": "/api/resourcelink"
  "svm": {
    "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
svm
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
