REST API reference
Retrieve the NIS configuration for the cluster
Retrieves the NIS configuration for your cluster, including both domain and server details. Use this information to understand the current NIS setup and identify which servers are successfully bound.
HTTP method and endpoint
GET /security/authentication/cluster/nis
Introduced in
ONTAP 9.6
Usage notes
Retrieves the NIS configuration of the cluster. Both NIS domain and servers are displayed by default. The bound_servers property indicates the successfully bound NIS servers.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
binding_details
array[binding_details]
An array of objects where each object represents the NIS server and it's status for a given NIS domain. It is an advanced field.
bound_servers
array[string]
domain
string
The NIS domain to which this configuration belongs.
servers
array[string]
A list of hostnames or IP addresses of NIS servers used by the NIS domain configuration.
      "href": "/api/resourcelink"
  "binding_details": [
      "server": "string",
      "status": {
        "code": "string",
        "message": "string"
  "bound_servers": [
    "string"
  "domain": "string",
  "servers": [
    "string"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
binding_status
code
string
Code corresponding to the server's binding status.
message
string
Detailed description of the server's binding status.
binding_details
server
string
Hostname/IP address of the NIS server in the domain.
status
binding_status
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
