REST API reference
Retrieve the NIS configuration for the cluster
Retrieves the NIS configuration for the cluster, giving you details about the NIS domain and servers by default.
HTTP method and endpoint
GET /security/authentication/cluster/nis
Introduced in
ONTAP 9.6
Usage notes
Retrieves the NIS configuration of the cluster. Both NIS domain and servers are displayed by default. The bound_servers property indicates the successfully bound NIS servers.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
desc] direction. Default direction is 'asc' for ascending.
fields
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
bound_servers
array[string]
domain
string
The NIS domain to which this configuration belongs.
servers
array[string]
A list of hostnames or IP addresses of NIS servers used by the NIS domain configuration.
      "href": "/api/resourcelink"
  "bound_servers": [
    "string"
  "domain": "string",
  "servers": [
    "string"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
