Retrieve the NIS configuration for the cluster
Retrieves the NIS configuration for your cluster, including both domain and server details. Use this information to understand the current NIS setup and identify which servers are successfully bound.
HTTP method and endpoint
GET /security/authentication/cluster/nis
Introduced in
ONTAP 9.6
Usage notes
Retrieves the NIS configuration of the cluster. Both NIS domain and servers are displayed by default.
The bound_servers property indicates the successfully bound NIS servers.
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
bound_servers |
array[string] |
domain |
string |
The NIS domain to which this configuration belongs. |
servers |
array[string] |
A list of hostnames or IP addresses of NIS servers used by the NIS domain configuration. |
"href": "/api/resourcelink"
"bound_servers": [
"string"
"domain": "string",
"servers": [
"string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
