REST API reference
Retrieve the NIS configuration for the cluster
GET /security/authentication/cluster/nis
Introduced In: 9.6
Retrieves the NIS configuration of the cluster. Both NIS domain and servers are displayed by default. The bound_servers property indicates the successfully bound NIS servers.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
desc] direction. Default direction is 'asc' for ascending.
fields
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
bound_servers
array[string]
domain
string
The NIS domain to which this configuration belongs.
servers
array[string]
A list of hostnames or IP addresses of NIS servers used by the NIS domain configuration.
      "href": "/api/resourcelink"
  "bound_servers": [
    "string"
  "domain": "string",
  "servers": [
    "string"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
