Retrieve the NIS configuration for the cluster
GET /security/authentication/cluster/nis
Retrieves the NIS configuration of the cluster. Both NIS domain and servers are displayed by default. The 'bound servers' field indicates the successfully bound NIS servers.
Learn more
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
bound_servers |
array[string] |
domain |
string |
The NIS domain to which this configuration belongs. |
servers |
array[string] |
A list of hostnames or IP addresses of NIS servers used by the NIS domain configuration. |
"href": "/api/resourcelink"
"bound_servers": [
"string"
"domain": "string",
"servers": [
"string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
