Retrieves google cloud kms configurations for all clusters and svms
security key-manager external gcp check
GET /security/gcp-kms
Introduced In: 9.9
Retrieves Google Cloud KMS configurations for all clusters and SVMs.
Related ONTAP commands
security key-manager external gcp show -
uuid |
string |
query |
False |
Filter by uuid |
proxy_username |
string |
query |
False |
Filter by proxy_username |
key_ring_name |
string |
query |
False |
Filter by key_ring_name |
svm.name |
string |
query |
False |
Filter by svm.name |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
proxy_type |
string |
query |
False |
Filter by proxy_type |
ekmip_reachability.node.uuid |
string |
query |
False |
Filter by ekmip_reachability.node.uuid |
ekmip_reachability.node.name |
string |
query |
False |
Filter by ekmip_reachability.node.name |
ekmip_reachability.code |
string |
query |
False |
Filter by ekmip_reachability.code |
ekmip_reachability.message |
string |
query |
False |
Filter by ekmip_reachability.message |
ekmip_reachability.reachable |
boolean |
query |
False |
Filter by ekmip_reachability.reachable |
scope |
string |
query |
False |
Filter by scope |
google_reachability.code |
string |
query |
False |
Filter by google_reachability.code |
google_reachability.reachable |
boolean |
query |
False |
Filter by google_reachability.reachable |
google_reachability.message |
string |
query |
False |
Filter by google_reachability.message |
proxy_port |
integer |
query |
False |
Filter by proxy_port |
key_ring_location |
string |
query |
False |
Filter by key_ring_location |
state.code |
string |
query |
False |
Filter by state.code |
state.message |
string |
query |
False |
Filter by state.message |
state.cluster_state |
boolean |
query |
False |
Filter by state.cluster_state |
key_name |
string |
query |
False |
Filter by key_name |
project_id |
string |
query |
False |
Filter by project_id |
proxy_host |
string |
query |
False |
Filter by proxy_host |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[gcp_kms] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"ekmip_reachability": [
"code": "346758",
"message": "embedded KMIP server status unavailable on node.",
"node": {
"name": "node1",
"google_reachability": {
"code": "346758",
"message": "Google Cloud KMS is not reachable from all nodes - <reason>."
"key_name": "cryptokey1",
"key_ring_location": "global",
"key_ring_name": "gcpapp1-keyring",
"project_id": "gcpapp1",
"proxy_host": "proxy.eng.com",
"proxy_port": 1234,
"proxy_type": "http",
"proxy_username": "proxyuser",
"scope": "string",
"state": {
"code": "346758",
"message": "Top-level internal key protection key (KEK) is unavailable on the following nodes with the associated reasons: Node: node1. Reason: No volumes created yet for the SVM. Wrapped KEK status will be available after creating encrypted volumes."
"svm": {
"name": "svm1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65537551 |
Top-level internal key protection key (KEK) unavailable on one or more nodes. |
65537552 |
Embedded KMIP server status not available. |
65537730 |
The Google Cloud Key Management Service is unreachable from one or more nodes. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
node
_links |
name |
string |
uuid |
string |
ekmip_reachability
Provides the connectivity status for the given SVM on the given node to all EKMIP servers configured on all nodes of the cluster.
This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
code |
string |
Code corresponding to the error message. Returns a 0 if a given SVM is able to communicate to the EKMIP servers of all of the nodes in the cluster. |
message |
string |
Error message set when cluster-wide EKMIP server availability from the given SVM and node is false. |
node |
reachable |
boolean |
Set to true if the given SVM on the given node is able to communicate to all EKMIP servers configured on all nodes in the cluster. |
google_reachability
Indicates whether or not the Google Cloud KMS is reachable from all nodes in the cluster.
code |
string |
Code corresponding to the error message. Returns a 0 if Google Cloud KMS is reachable from all nodes in the cluster. |
message |
string |
Set to the error message when 'reachable' is false. |
reachable |
boolean |
Set to true if the Google Cloud KMS is reachable from all nodes of the cluster. |
state
Google Cloud Key Management Services is a cloud key management service (KMS) that provides a secure store for encryption keys. This object indicates whether or not the Google Cloud KMS key protection is available on all nodes in the cluster.
cluster_state |
boolean |
Set to true when Google Cloud KMS key protection is available on all nodes of the cluster. |
code |
string |
Error code corresponding to the status message. Returns 0 if Google Cloud KMS key protection is available in all nodes of the cluster. |
message |
string |
Error message set when top-level internal key protection key (KEK) availability on cluster is false. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
gcp_kms
_links |
ekmip_reachability |
array[ekmip_reachability] |
google_reachability |
This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the |
key_name |
string |
Key Identifier of Google Cloud KMS key encryption key. |
key_ring_location |
string |
Google Cloud KMS key ring location. |
key_ring_name |
string |
Google Cloud KMS key ring name of the deployed Google Cloud application. |
project_id |
string |
Google Cloud project (application) ID of the deployed Google Cloud application that has appropriate access to the Google Cloud KMS. |
proxy_host |
string |
Proxy host name. |
proxy_port |
integer |
Proxy port number. |
proxy_type |
string |
Type of proxy. |
proxy_username |
string |
Proxy username. |
scope |
string |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster". |
state |
svm |
uuid |
string |
A unique identifier for the Google Cloud KMS. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
