REST API reference
Retrieves google cloud kms configurations for all clusters and svms
  • security key-manager external gcp check
GET /security/gcp-kms
Introduced In: 9.9
Retrieves Google Cloud KMS configurations for all clusters and SVMs.
  • security key-manager external gcp show
key_ring_name
string
query
False
Filter by key_ring_name
key_name
string
query
False
Filter by key_name
proxy_port
integer
query
False
Filter by proxy_port
uuid
string
query
False
Filter by uuid
state.cluster_state
boolean
query
False
Filter by state.cluster_state
state.code
integer
query
False
Filter by state.code
state.message
string
query
False
Filter by state.message
scope
string
query
False
Filter by scope
key_ring_location
string
query
False
Filter by key_ring_location
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
proxy_type
string
query
False
Filter by proxy_type
ekmip_reachability.message
string
query
False
Filter by ekmip_reachability.message
ekmip_reachability.node.name
string
query
False
Filter by ekmip_reachability.node.name
ekmip_reachability.node.uuid
string
query
False
Filter by ekmip_reachability.node.uuid
ekmip_reachability.code
integer
query
False
Filter by ekmip_reachability.code
ekmip_reachability.reachable
boolean
query
False
Filter by ekmip_reachability.reachable
proxy_username
string
query
False
Filter by proxy_username
google_reachability.code
integer
query
False
Filter by google_reachability.code
google_reachability.reachable
boolean
query
False
Filter by google_reachability.reachable
google_reachability.message
string
query
False
Filter by google_reachability.message
project_id
string
query
False
Filter by project_id
proxy_host
string
query
False
Filter by proxy_host
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value: 1
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[gcp_kms]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "ekmip_reachability": [
          "code": "346758",
          "message": "embedded KMIP server status unavailable on node.",
          "node": {
            "name": "node1",
      "google_reachability": {
        "code": "346758",
        "message": "Google Cloud KMS service is not reachable from all nodes - <reason>."
      "key_name": "cryptokey1",
      "key_ring_location": "global",
      "key_ring_name": "gcpapp1-keyring",
      "project_id": "gcpapp1",
      "proxy_host": "proxy.eng.com",
      "proxy_port": "1234",
      "proxy_type": "http",
      "proxy_username": "proxyuser",
      "scope": "string",
      "state": {
        "code": "346758",
        "message": "Top-level internal key protection key (KEK) is unavailable on the following nodes with the associated reasons: Node: node1. Reason: No volumes created yet for the SVM. Wrapped KEK status will be available after creating encrypted volumes."
      "svm": {
        "name": "svm1",
Status: Default
ONTAP Error Response Codes
Error Code Description
65537551
Top-level internal key protection key (KEK) unavailable on one or more nodes.
65537552
Embedded KMIP server status not available.
65537730
The Google Cloud Key Management Service is unreachable from one or more nodes.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
node
_links
_links
name
string
uuid
string
ekmip_reachability
Provides the connectivity status for the given SVM on the given node to all EKMIP servers configured on all nodes of the cluster. This is an advanced property; there is an added cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
code
integer
Code corresponding to the error message. Returns a 0 if a given SVM is able to communicate to the EKMIP servers of all of the nodes in the cluster.
message
string
Error message set when cluster-wide EKMIP server availability from the given SVM and node is false.
node
node
reachable
boolean
Set to true if the given SVM on the given node is able to communicate to all EKMIP servers configured on all nodes in the cluster.
google_reachability
Indicates whether or not the Google Cloud KMS service is reachable from all nodes in the cluster. This is an advanced property; there is an added cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
code
integer
Code corresponding to the error message. Returns a 0 if Google Cloud KMS service is reachable from all nodes in the cluster.
message
string
Set to the error message when 'reachable' is false.
reachable
boolean
Set to true if the Google Cloud KMS service is reachable from all nodes of the cluster.
state
Google Cloud Key Management Services is a cloud key management service (KMS) that provides a secure store for encryption keys. This object indicates whether or not the Google Cloud KMS key protection is available on all nodes in the cluster. This is an advanced property; there is an added cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
cluster_state
boolean
Set to true when Google Cloud KMS key protection is available on all nodes of the cluster.
code
integer
Error code corresponding to the status message. Returns 0 if Google Cloud KMS key protection is available in all nodes of the cluster.
message
string
Error message set when top-level internal key protection key (KEK) availability on cluster is false.
svm
_links
_links
name
string
The name of the SVM.
uuid
string
gcp_kms
_links
_links
ekmip_reachability
array[ekmip_reachability]
google_reachability
google_reachability
key_name
string
Key Identifier of Google Cloud KMS key encryption key.
key_ring_location
string
Google Cloud KMS key ring location.
key_ring_name
string
Google Cloud KMS key ring name of the deployed Google Cloud application.
project_id
string
Google Cloud project (application) ID of the deployed Google Cloud application that has appropriate access to the Google Cloud KMS.
proxy_host
string
Proxy host name.
proxy_port
integer
Proxy port number.
proxy_type
string
Type of proxy.
proxy_username
string
Proxy username.
scope
string
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster".
state
state
svm
svm
uuid
string
A unique identifier for the Google Cloud KMS.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
