REST API reference
Retrieve a Google Cloud KMS configurations for all clusters and SVMs
Accesses Google Cloud KMS configurations across all clusters and SVMs to review or manage their settings.
HTTP method and endpoint
GET /security/gcp-kms
Introduced in
ONTAP 9.9
Usage notes
Retrieves Google Cloud KMS configurations for all clusters and SVMs.
  • security key-manager external gcp show
  • security key-manager external gcp check
verify_host
boolean
query
False
Filter by verify_host
  • Introduced in: 9.14
proxy_host
string
query
False
Filter by proxy_host
key_ring_location
string
query
False
Filter by key_ring_location
port
integer
query
False
Filter by port
ekmip_reachability.message
string
query
False
Filter by ekmip_reachability.message
ekmip_reachability.node.name
string
query
False
Filter by ekmip_reachability.node.name
ekmip_reachability.node.uuid
string
query
False
Filter by ekmip_reachability.node.uuid
ekmip_reachability.reachable
boolean
query
False
Filter by ekmip_reachability.reachable
ekmip_reachability.code
string
query
False
Filter by ekmip_reachability.code
cloudkms_host
string
query
False
Filter by cloudkms_host
caller_account
string
query
False
Filter by caller_account
proxy_username
string
query
False
Filter by proxy_username
google_reachability.message
string
query
False
Filter by google_reachability.message
google_reachability.code
string
query
False
Filter by google_reachability.code
google_reachability.reachable
boolean
query
False
Filter by google_reachability.reachable
proxy_port
integer
query
False
Filter by proxy_port
key_ring_name
string
query
False
Filter by key_ring_name
oauth_host
string
query
False
Filter by oauth_host
verify_ip
boolean
query
False
Filter by verify_ip
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
authentication_method
string
query
False
Filter by authentication_method
  • Introduced in: 9.17
project_id
string
query
False
Filter by project_id
gce_metadata_server
string
query
False
Filter by gce_metadata_server
uuid
string
query
False
Filter by uuid
oauth_url
string
query
False
Filter by oauth_url
key_name
string
query
False
Filter by key_name
state.cluster_state
boolean
query
False
Filter by state.cluster_state
state.message
string
query
False
Filter by state.message
state.code
string
query
False
Filter by state.code
privileged_account
string
query
False
Filter by privileged_account
proxy_type
string
query
False
Filter by proxy_type
scope
string
query
False
Filter by scope
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value: 1
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[gcp_kms]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "authentication_method": "application_credentials_key",
      "caller_account": "myaccount@myproject.com",
      "cloudkms_host": "cloudkms.googleapis.com",
      "ekmip_reachability": [
          "code": "346758",
          "message": "embedded KMIP server status unavailable on node.",
          "node": {
            "name": "node1",
      "gce_metadata_server": "http://169.254.169.254/computeMetadata/v1/instance/service-accounts/default/token",
      "google_reachability": {
        "code": "346758",
        "message": "Google Cloud KMS is not reachable from all nodes - <reason>."
      "key_name": "cryptokey1",
      "key_ring_location": "global",
      "key_ring_name": "gcpapp1-keyring",
      "oauth_host": "oauth2.googleapis.com",
      "oauth_url": "https://oauth2.googleapis.com/token",
      "port": 443,
      "privileged_account": "myserviceaccount@myproject.iam.gserviceaccount.com",
      "project_id": "gcpapp1",
      "proxy_host": "proxy.eng.com",
      "proxy_port": 1234,
      "proxy_type": "http",
      "proxy_username": "proxyuser",
      "scope": "string",
      "state": {
        "code": "346758",
        "message": "Top-level internal key protection key (KEK) is unavailable on the following nodes with the associated reasons: Node: node1. Reason: No volumes created yet for the SVM. Wrapped KEK status will be available after creating encrypted volumes."
      "svm": {
        "name": "svm1",
Status: Default
ONTAP Error Response Codes
Error Code Description
65537551
Top-level internal key protection key (KEK) unavailable on one or more nodes.
65537552
Embedded KMIP server status not available.
65537730
The Google Cloud Key Management Service is unreachable from one or more nodes.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
node
_links
_links
name
string
uuid
string
ekmip_reachability
Provides the connectivity status for the given SVM on the given node to all EKMIP servers configured on all nodes of the cluster. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
code
string
Code corresponding to the error message. Returns a 0 if a given SVM is able to communicate to the EKMIP servers of all of the nodes in the cluster.
message
string
Error message set when cluster-wide EKMIP server availability from the given SVM and node is false.
node
node
reachable
boolean
Set to true if the given SVM on the given node is able to communicate to all EKMIP servers configured on all nodes in the cluster.
google_reachability
Indicates whether or not the Google Cloud KMS is reachable from all nodes in the cluster. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
code
string
Code corresponding to the error message. Returns a 0 if Google Cloud KMS is reachable from all nodes in the cluster.
message
string
Set to the error message when 'reachable' is false.
reachable
boolean
Set to true if the Google Cloud KMS is reachable from all nodes of the cluster.
state
Google Cloud Key Management Services is a cloud key management service (KMS) that provides a secure store for encryption keys. This object indicates whether or not the Google Cloud KMS key protection is available on all nodes in the cluster. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
cluster_state
boolean
Set to true when Google Cloud KMS key protection is available on all nodes of the cluster.
code
string
Error code corresponding to the status message. Returns 0 if Google Cloud KMS key protection is available in all nodes of the cluster.
message
string
Error message set when top-level internal key protection key (KEK) availability on cluster is false.
svm
_links
_links
name
string
uuid
string
gcp_kms
_links
_links
string
Google Cloud KMS authentication method.
caller_account
string
Google Cloud KMS caller account email
cloudkms_host
string
Google Cloud KMS host subdomain.
ekmip_reachability
array[ekmip_reachability]
gce_metadata_server
string
A custom metadata server URL used for retrieving short lived authentication tokens if the default service account is not used. This is only applicable when the authentication_method is set to sa_credentials_attachment.
google_reachability
google_reachability
key_name
string
Key Identifier of Google Cloud KMS key encryption key.
key_ring_location
string
Google Cloud KMS key ring location.
key_ring_name
string
Google Cloud KMS key ring name of the deployed Google Cloud application.
oauth_host
string
Open authorization server host name.
oauth_url
string
Open authorization URL for the access token.
port
integer
Authorization server and Google Cloud KMS port number.
privileged_account
string
Google Cloud KMS account to impersonate.
project_id
string
Google Cloud project (application) ID of the deployed Google Cloud application that has appropriate access to the Google Cloud KMS.
proxy_host
string
Proxy host name.
proxy_port
integer
Proxy port number.
proxy_type
string
Type of proxy.
proxy_username
string
Proxy username.
scope
string
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster".
state
state
svm
svm
uuid
string
A unique identifier for the Google Cloud KMS.
verify_host
boolean
Verify the identity of the Google Cloud KMS host name.
verify_ip
boolean
Verify the identity of the Google Cloud KMS IP address.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
