Retrieve QoS policies
Retrieves a collection of QoS policies, which helps you manage and optimize the performance of your storage resources based on defined quality of service rules.
HTTP method and endpoint
GET /storage/qos/policies
Introduced in
ONTAP 9.6
name |
string |
query |
False |
Filter by name |
uuid |
string |
query |
False |
Filter by uuid |
fixed.max_throughput_mbps |
integer |
query |
False |
Filter by fixed.max_throughput_mbps |
fixed.min_throughput_iops |
integer |
query |
False |
Filter by fixed.min_throughput_iops |
fixed.min_throughput_mbps |
integer |
query |
False |
Filter by fixed.min_throughput_mbps
fixed.capacity_shared |
boolean |
query |
False |
Filter by fixed.capacity_shared |
fixed.max_throughput_iops |
integer |
query |
False |
Filter by fixed.max_throughput_iops |
scope |
string |
query |
False |
Filter by scope
policy_class |
string |
query |
False |
Filter by policy_class
object_count |
integer |
query |
False |
Filter by object_count |
adaptive.expected_iops |
integer |
query |
False |
Filter by adaptive.expected_iops |
adaptive.peak_iops_allocation |
string |
query |
False |
Filter by adaptive.peak_iops_allocation
adaptive.absolute_min_iops |
integer |
query |
False |
Filter by adaptive.absolute_min_iops |
adaptive.peak_iops |
integer |
query |
False |
Filter by adaptive.peak_iops |
adaptive.block_size |
string |
query |
False |
Filter by adaptive.block_size
adaptive.expected_iops_allocation |
string |
query |
False |
Filter by adaptive.expected_iops_allocation
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
pgid |
integer |
query |
False |
Filter by pgid
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
error |
num_records |
integer |
Number of records |
records |
array[qos_policy] |
"next": {
"href": "/api/resourcelink"
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
"num_records": 1,
"records": [
"adaptive": {
"block_size": "string",
"expected_iops_allocation": "string",
"peak_iops_allocation": "string"
"name": "extreme",
"object_count": 0,
"pgid": 0,
"policy_class": "string",
"scope": "string",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
_links
self |
adaptive
Adaptive QoS policy-groups define measurable service level objectives (SLOs) that adjust based on the storage object used space and the storage object allocated space.
absolute_min_iops |
integer |
Specifies the absolute minimum IOPS that is used as an override when the expected_iops is less than this value. These floors are not guaranteed on non-AFF platforms or when FabricPool tiering policies are set. |
block_size |
string |
Specifies the block size |
expected_iops |
integer |
Expected IOPS. Specifies the minimum expected IOPS per TB allocated based on the storage object allocated size. These floors are not guaranteed on non-AFF platforms or when FabricPool tiering policies are set. |
string |
Specifies the size to be used to calculate expected IOPS per TB. The size options are either the storage object allocated space or the storage object used space. |
peak_iops |
integer |
Peak IOPS. Specifies the maximum possible IOPS per TB allocated based on the storage object allocated size or the storage object used size. |
string |
Specifies the size to be used to calculate peak IOPS per TB. The size options are either the storage object allocated space or the storage object used space. |
fixed
QoS policy-groups define a fixed service level objective (SLO) for a storage object.
capacity_shared |
boolean |
Specifies whether the capacities are shared across all objects that use this QoS policy-group. Default is false. |
integer |
Maximum throughput defined by this policy. It is specified in terms of IOPS. 0 means no maximum throughput is enforced. |
integer |
Maximum throughput defined by this policy. It is specified in terms of Mbps. 0 means no maximum throughput is enforced. |
integer |
Minimum throughput defined by this policy. It is specified in terms of IOPS. 0 means no minimum throughput is enforced. These floors are not guaranteed on non-AFF platforms or when FabricPool tiering policies are set. |
integer |
Minimum throughput defined by this policy. It is specified in terms of Mbps. 0 means no minimum throughput is enforced. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
qos_policy
_links |
adaptive |
Adaptive QoS policy-groups define measurable service level objectives (SLOs) that adjust based on the storage object used space and the storage object allocated space. |
fixed |
QoS policy-groups define a fixed service level objective (SLO) for a storage object. |
name |
string |
Name of the QoS policy. |
object_count |
integer |
Number of objects attached to this policy. |
pgid |
integer |
Policy group ID of the QoS policy. |
policy_class |
string |
Class of the QoS policy. |
scope |
string |
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects. |
svm |
uuid |
string |
