REST API reference
Retrieve QoS policies
Retrieves a list of QoS policies to view their configurations and manage quality of service for your storage resources.
HTTP method and endpoint
GET /storage/qos/policies
Introduced in
ONTAP 9.6
Usage notes
Retrieves a collection of QoS policies.
adaptive.expected_iops_allocation
string
query
False
Filter by adaptive.expected_iops_allocation
  • Introduced in: 9.10
adaptive.peak_iops
integer
query
False
Filter by adaptive.peak_iops
adaptive.block_size
string
query
False
Filter by adaptive.block_size
adaptive.absolute_min_iops
integer
query
False
Filter by adaptive.absolute_min_iops
adaptive.peak_iops_allocation
string
query
False
Filter by adaptive.peak_iops_allocation
integer
query
False
fixed.max_throughput_iops
integer
query
False
Filter by fixed.max_throughput_iops
  • Max value: 2147483647
  • Min value: 0
fixed.min_throughput_iops
integer
query
False
Filter by fixed.min_throughput_iops
  • Min value: 0
fixed.max_throughput_mbps
integer
query
False
Filter by fixed.max_throughput_mbps
  • Max value: 4194303
  • Min value: 0
fixed.min_throughput_mbps
integer
query
False
Filter by fixed.min_throughput_mbps
  • Introduced in: 9.8
  • Min value: 0
fixed.capacity_shared
boolean
query
False
Filter by fixed.capacity_shared
policy_class
string
query
False
Filter by policy_class
name
string
query
False
Filter by name
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
object_count
integer
query
False
Filter by object_count
uuid
string
query
False
Filter by uuid
pgid
integer
query
False
Filter by pgid
scope
string
query
False
Filter by scope
  • Introduced in: 9.11
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Max value: 120
  • Min value: 0
  • Default value: 15
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
error
error
num_records
integer
Number of records
records
array[qos_policy]
    "next": {
      "href": "/api/resourcelink"
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "message": "entry doesn't exist"
  "num_records": 1,
  "records": [
      "adaptive": {
        "block_size": "string",
        "expected_iops_allocation": "string",
        "peak_iops_allocation": "string"
      "name": "extreme",
      "object_count": 0,
      "pgid": 0,
      "policy_class": "string",
      "scope": "string",
      "svm": {
        "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
self
adaptive
Adaptive QoS policy-groups define measurable service level objectives (SLOs) that adjust based on the storage object used space and the storage object allocated space.
absolute_min_iops
integer
Specifies the absolute minimum IOPS that is used as an override when the expected_iops is less than this value. These floors are not guaranteed on non-AFF platforms or when FabricPool tiering policies are set.
block_size
string
Specifies the block size
expected_iops
integer
Expected IOPS. Specifies the minimum expected IOPS per TB allocated based on the storage object allocated size. These floors are not guaranteed on non-AFF platforms or when FabricPool tiering policies are set.
string
Specifies the size to be used to calculate expected IOPS per TB. The size options are either the storage object allocated space or the storage object used space.
peak_iops
integer
Peak IOPS. Specifies the maximum possible IOPS per TB allocated based on the storage object allocated size or the storage object used size.
string
Specifies the size to be used to calculate peak IOPS per TB. The size options are either the storage object allocated space or the storage object used space.
fixed
QoS policy-groups define a fixed service level objective (SLO) for a storage object.
capacity_shared
boolean
Specifies whether the capacities are shared across all objects that use this QoS policy-group. Default is false.
max_throughput_iops
integer
Maximum throughput defined by this policy. It is specified in terms of IOPS. 0 means no maximum throughput is enforced.
max_throughput_mbps
integer
Maximum throughput defined by this policy. It is specified in terms of Mbps. 0 means no maximum throughput is enforced.
min_throughput_iops
integer
Minimum throughput defined by this policy. It is specified in terms of IOPS. 0 means no minimum throughput is enforced. These floors are not guaranteed on non-AFF platforms or when FabricPool tiering policies are set.
min_throughput_mbps
integer
Minimum throughput defined by this policy. It is specified in terms of Mbps. 0 means no minimum throughput is enforced.
svm
_links
_links
name
string
uuid
string
qos_policy
_links
_links
adaptive
adaptive
fixed
fixed
name
string
Name of the QoS policy.
object_count
integer
Number of objects attached to this policy.
pgid
integer
Policy group ID of the QoS policy.
policy_class
string
Class of the QoS policy.
scope
string
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects.
svm
svm
uuid
string
returned_error
arguments
Message arguments
code
string
Error code
message
string
Error message
target
string
