REST API reference
Retrieve QoS policies
Retrieves a collection of QoS policies to review or manage the quality of service settings applied to your storage resources.
HTTP method and endpoint
GET /storage/qos/policies
Introduced in
ONTAP 9.6
pgid
integer
query
False
Filter by pgid
  • Introduced in: 9.10
uuid
string
query
False
Filter by uuid
object_count
integer
query
False
Filter by object_count
policy_class
string
query
False
Filter by policy_class
fixed.max_throughput_iops
integer
query
False
Filter by fixed.max_throughput_iops
  • Max value: 2147483647
  • Min value: 0
fixed.max_throughput_mbps
integer
query
False
Filter by fixed.max_throughput_mbps
  • Max value: 4194303
  • Min value: 0
fixed.capacity_shared
boolean
query
False
Filter by fixed.capacity_shared
string
query
False
  • Introduced in: 9.17
fixed.min_throughput
string
query
False
Filter by fixed.min_throughput
fixed.min_throughput_iops
integer
query
False
Filter by fixed.min_throughput_iops
  • Min value: 0
fixed.min_throughput_mbps
integer
query
False
Filter by fixed.min_throughput_mbps
  • Introduced in: 9.8
  • Min value: 0
scope
string
query
False
Filter by scope
  • Introduced in: 9.11
burst.duration
integer
query
False
Filter by burst.duration
  • Introduced in: 9.19
  • Max value: 3600
  • Min value: 1
burst.percent
integer
query
False
Filter by burst.percent
  • Min value: 0
burst.iops
integer
query
False
Filter by burst.iops
  • Min value: 0
name
string
query
False
Filter by name
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
adaptive.absolute_min_iops
integer
query
False
Filter by adaptive.absolute_min_iops
adaptive.expected_iops_allocation
string
query
False
Filter by adaptive.expected_iops_allocation
adaptive.block_size
string
query
False
Filter by adaptive.block_size
integer
query
False
adaptive.peak_iops_allocation
string
query
False
Filter by adaptive.peak_iops_allocation
adaptive.peak_iops
integer
query
False
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Max value: 120
  • Min value: 0
  • Default value: 15
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
error
error
num_records
integer
Number of records
records
array[qos_policy]
    "next": {
      "href": "/api/resourcelink"
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "message": "entry doesn't exist"
  "num_records": 1,
  "records": [
      "adaptive": {
        "block_size": "string",
        "expected_iops_allocation": "string",
        "peak_iops_allocation": "string"
      "fixed": {
        "max_throughput": [
          "900KB/s",
          "500MB/s",
          "120GB/s",
          "5000IOPS",
          "5000IOPS,500KB/s",
          "2500IOPS,100MB/s",
          "1000IOPS,25MB/s"
        "min_throughput": [
          "900KB/s",
          "500MB/s",
          "120GB/s",
          "5000IOPS",
          "5000IOPS,500KB/s",
          "2500IOPS,100MB/s",
          "1000IOPS,25MB/s"
      "name": "extreme",
      "object_count": 0,
      "pgid": 0,
      "policy_class": "string",
      "scope": "string",
      "svm": {
        "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
self
adaptive
Adaptive QoS policy-groups define measurable service level objectives (SLOs) that adjust based on the storage object used space and the storage object allocated space.
absolute_min_iops
integer
Specifies the absolute minimum IOPS that is used as an override when the expected_iops is less than this value. These floors are not guaranteed on non-AFF platforms or when FabricPool tiering policies are set.
block_size
string
Specifies the block size
expected_iops
integer
Expected IOPS. Specifies the minimum expected IOPS per TB allocated based on the storage object allocated size. These floors are not guaranteed on non-AFF platforms or when FabricPool tiering policies are set.
string
Specifies the size to be used to calculate expected IOPS per TB. The size options are either the storage object allocated space or the storage object used space.
peak_iops
integer
Peak IOPS. Specifies the maximum possible IOPS per TB allocated based on the storage object allocated size or the storage object used size.
string
Specifies the size to be used to calculate peak IOPS per TB. The size options are either the storage object allocated space or the storage object used space.
burst
Burst settings for the QoS policy.
duration
integer
Amount of time in seconds a policy can burst at either the maximum percentage or maximum IOPS above the set limit.
iops
integer
Burst maximum IOPS for a policy max_throughput or peak_iops. Policy max_throughput must have an IOPS component. If burst_iops is less than max_throughput or peak_iops, then max_throughput or peak_iops is used. This is mutually exclusive with burst_percent.
percent
integer
Percentage of IOPS or throughput above policy max_throughput or peak_iops. This is mutually exclusive with burst_iops.
fixed
QoS policy-groups define a fixed service level objective (SLO) for a storage object.
capacity_shared
boolean
Specifies whether the capacities are shared across all objects that use this QoS policy-group. Default is false.
max_throughput
string
Maximum throughput defined by this policy. It is specified in terms of Kbps, Mbps or Gbps along with or without IOPS. 0 means no maximum throughput is enforced.
max_throughput_iops
integer
Maximum throughput defined by this policy. It is specified in terms of IOPS. 0 means no maximum throughput is enforced.
max_throughput_mbps
integer
Maximum throughput defined by this policy. It is specified in terms of Mbps. 0 means no maximum throughput is enforced.
min_throughput
string
Minimum throughput defined by this policy. It is specified in terms of Kbps, Mbps or Gbps along with or without IOPS. 0 means no minimum throughput is enforced.
min_throughput_iops
integer
Minimum throughput defined by this policy. It is specified in terms of IOPS. 0 means no minimum throughput is enforced. These floors are not guaranteed on non-AFF platforms or when FabricPool tiering policies are set.
min_throughput_mbps
integer
Minimum throughput defined by this policy. It is specified in terms of Mbps. 0 means no minimum throughput is enforced.
svm
_links
_links
name
string
uuid
string
qos_policy
_links
_links
adaptive
adaptive
burst
burst
fixed
fixed
name
string
Name of the QoS policy.
object_count
integer
Number of objects attached to this policy.
pgid
integer
Policy group ID of the QoS policy.
policy_class
string
Class of the QoS policy.
scope
string
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects.
svm
svm
uuid
string
returned_error
arguments
Message arguments
code
string
Error code
message
string
Error message
target
string
