REST API reference
Retrieve tape devices
Retrieves a collection of tape devices, providing an overview of the available tape resources.
HTTP method and endpoint
GET /storage/tape-devices
Introduced in
ONTAP 9.9
  • storage tape show
node.uuid
string
query
False
Filter by node.uuid
node.name
string
query
False
Filter by node.name
wwpn
string
query
False
Filter by wwpn
device_id
string
query
False
Filter by device_id
type
string
query
False
Filter by type
device_names.no_rewind_device
string
query
False
Filter by device_names.no_rewind_device
device_names.unload_reload_device
string
query
False
Filter by device_names.unload_reload_device
device_names.rewind_device
string
query
False
Filter by device_names.rewind_device
residual_count
integer
query
False
Filter by residual_count
wwnn
string
query
False
Filter by wwnn
aliases.name
string
query
False
Filter by aliases.name
  • Introduced in: 9.11
aliases.mapping
string
query
False
Filter by aliases.mapping
alias.mapping
string
query
False
Filter by alias.mapping
alias.name
string
query
False
Filter by alias.name
file_number
integer
query
False
Filter by file_number
block_number
integer
query
False
Filter by block_number
interface
string
query
False
Filter by interface
serial_number
string
query
False
Filter by serial_number
description
string
query
False
Filter by description
online
boolean
query
False
Filter by online
formats
string
query
False
Filter by formats
reservation_type
string
query
False
Filter by reservation_type
device_state
string
query
False
Filter by device_state
density
string
query
False
Filter by density
storage_port.name
string
query
False
Filter by storage_port.name
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[tape_device]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "alias": {
        "mapping": "SN[10WT000933]",
        "name": "st6"
      "aliases": [
          "name": "st6"
      "block_number": 0,
      "density": "low",
      "description": "QUANTUM LTO-8 ULTRIUM",
      "device_id": "1a.0",
      "device_names": [
          "no_rewind_device": "nrst6l",
          "rewind_device": "rst6l",
          "unload_reload_device": "urst6l"
      "device_state": "read_write_enabled",
      "file_number": 0,
      "formats": [
        "LTO-7 6TB",
        "LTO-7 15TB Compressed",
        "LTO-8 12TB",
        "LTO-8 30TB Compressed"
      "interface": "sas",
      "node": {
        "name": "node1",
      "position": {
        "count": 5,
        "operation": "rewind"
      "reservation_type": "off",
      "residual_count": 0,
      "serial_number": "10WT00093",
      "storage_port": {
        "name": "2b"
      "type": "tape",
      "wwnn": "500507631295741c",
      "wwpn": "500507631295741c"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
alias
mapping
string
This field will no longer be supported in a future release. Use aliases.mapping instead.
name
string
This field will no longer be supported in a future release. Use aliases.name instead.
aliases
mapping
string
Alias mapping.
name
string
Alias name.
device_names
no_rewind_device
string
Device name for no rewind.
rewind_device
string
Device name for rewind.
string
Device name for unload or reload operations.
self
node
_links
_links
name
string
uuid
string
position
count
integer
Number of times to run position operation.
operation
string
Position operation.
storage_port
name
string
Initiator port.
tape_device
alias
alias
aliases
array[aliases]
block_number
integer
Block number.
density
string
Density.
description
string
device_id
string
device_names
array[device_names]
device_state
string
Operational state of the device.
file_number
integer
File number.
formats
array[string]
Tape cartridge format.
interface
string
Device interface type.
node
node
online
boolean
position
position
reservation_type
string
residual_count
integer
Residual count of the last I/O operation.
serial_number
string
storage_port
storage_port
type
string
Device type.
wwnn
string
World Wide Node Name.
wwpn
string
World Wide Port Name.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
