REST API reference
Retrieve tape devices
GET /storage/tape-devices
Introduced In: 9.9
Retrieves a collection of tape devices.
  • storage tape show
wwnn
string
query
False
Filter by wwnn
alias.mapping
string
query
False
Filter by alias.mapping
alias.name
string
query
False
Filter by alias.name
residual_count
integer
query
False
Filter by residual_count
aliases.mapping
string
query
False
Filter by aliases.mapping
  • Introduced in: 9.11
aliases.name
string
query
False
Filter by aliases.name
reservation_type
string
query
False
Filter by reservation_type
node.name
string
query
False
Filter by node.name
node.uuid
string
query
False
Filter by node.uuid
type
string
query
False
Filter by type
wwpn
string
query
False
Filter by wwpn
density
string
query
False
Filter by density
description
string
query
False
Filter by description
device_id
string
query
False
Filter by device_id
device_state
string
query
False
Filter by device_state
interface
string
query
False
Filter by interface
online
boolean
query
False
Filter by online
device_names.rewind_device
string
query
False
Filter by device_names.rewind_device
device_names.unload_reload_device
string
query
False
Filter by device_names.unload_reload_device
device_names.no_rewind_device
string
query
False
Filter by device_names.no_rewind_device
block_number
integer
query
False
Filter by block_number
formats
string
query
False
Filter by formats
storage_port.name
string
query
False
Filter by storage_port.name
file_number
integer
query
False
Filter by file_number
serial_number
string
query
False
Filter by serial_number
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[tape_device]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "alias": {
        "mapping": "SN[10WT000933]",
        "name": "st6"
      "aliases": [
          "name": "st6"
      "block_number": 0,
      "density": "low",
      "description": "QUANTUM LTO-8 ULTRIUM",
      "device_id": "1a.0",
      "device_names": [
          "no_rewind_device": "nrst6l",
          "rewind_device": "rst6l",
          "unload_reload_device": "urst6l"
      "device_state": "read_write_enabled",
      "file_number": 0,
      "formats": [
        "LTO-7 6TB",
        "LTO-7 15TB Compressed",
        "LTO-8 12TB",
        "LTO-8 30TB Compressed"
      "interface": "sas",
      "node": {
        "name": "node1",
      "position": {
        "count": 5,
        "operation": "rewind"
      "reservation_type": "off",
      "residual_count": 0,
      "serial_number": "10WT00093",
      "storage_port": {
        "name": "2b"
      "type": "tape",
      "wwnn": "500507631295741c",
      "wwpn": "500507631295741c"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
alias
mapping
string
This field will no longer be supported in a future release. Use aliases.mapping instead.
name
string
This field will no longer be supported in a future release. Use aliases.name instead.
aliases
mapping
string
Alias mapping.
name
string
Alias name.
device_names
no_rewind_device
string
Device name for no rewind.
rewind_device
string
Device name for rewind.
string
Device name for unload or reload operations.
self
node
_links
_links
name
string
uuid
string
position
count
integer
Number of times to run position operation.
operation
string
Position operation.
storage_port
name
string
Initiator port.
tape_device
alias
alias
aliases
array[aliases]
block_number
integer
Block number.
density
string
Density.
description
string
device_id
string
device_names
array[device_names]
device_state
string
Operational state of the device.
file_number
integer
File number.
formats
array[string]
Tape cartridge format.
interface
string
Device interface type.
node
node
online
boolean
position
position
reservation_type
string
residual_count
integer
Residual count of the last I/O operation.
serial_number
string
storage_port
storage_port
type
string
Device type.
wwnn
string
World Wide Node Name.
wwpn
string
World Wide Port Name.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
