Retrieve tape devices
Retrieves a collection of tape devices to view the available tape storage options and their configurations.
HTTP method and endpoint
GET /storage/tape-devices
Introduced in
ONTAP 9.9
Related ONTAP commands
storage tape show
Learn more
device_state |
string |
query |
False |
Filter by device_state |
residual_count |
integer |
query |
False |
Filter by residual_count |
node.uuid |
string |
query |
False |
Filter by node.uuid |
node.name |
string |
query |
False |
Filter by node.name |
device_names.unload_reload_device |
string |
query |
False |
Filter by device_names.unload_reload_device |
device_names.no_rewind_device |
string |
query |
False |
Filter by device_names.no_rewind_device |
device_names.rewind_device |
string |
query |
False |
Filter by device_names.rewind_device |
wwnn |
string |
query |
False |
Filter by wwnn |
block_number |
integer |
query |
False |
Filter by block_number |
density |
string |
query |
False |
Filter by density
reservation_type |
string |
query |
False |
Filter by reservation_type |
interface |
string |
query |
False |
Filter by interface |
type |
string |
query |
False |
Filter by type |
online |
boolean |
query |
False |
Filter by online
aliases.name |
string |
query |
False |
Filter by aliases.name
aliases.mapping |
string |
query |
False |
Filter by aliases.mapping
formats |
string |
query |
False |
Filter by formats |
file_number |
integer |
query |
False |
Filter by file_number |
alias.mapping |
string |
query |
False |
Filter by alias.mapping |
alias.name |
string |
query |
False |
Filter by alias.name |
device_id |
string |
query |
False |
Filter by device_id |
storage_port.name |
string |
query |
False |
Filter by storage_port.name |
description |
string |
query |
False |
Filter by description |
wwpn |
string |
query |
False |
Filter by wwpn |
serial_number |
string |
query |
False |
Filter by serial_number |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[tape_device] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"alias": {
"mapping": "SN[10WT000933]",
"name": "st6"
"aliases": [
"name": "st6"
"block_number": 0,
"density": "low",
"description": "QUANTUM LTO-8 ULTRIUM",
"device_id": "1a.0",
"device_names": [
"no_rewind_device": "nrst6l",
"rewind_device": "rst6l",
"unload_reload_device": "urst6l"
"device_state": "read_write_enabled",
"file_number": 0,
"formats": [
"LTO-7 6TB",
"LTO-7 15TB Compressed",
"LTO-8 12TB",
"LTO-8 30TB Compressed"
"interface": "sas",
"node": {
"name": "node1",
"position": {
"count": 5,
"operation": "rewind"
"reservation_type": "off",
"residual_count": 0,
"serial_number": "10WT00093",
"storage_port": {
"name": "2b"
"type": "tape",
"wwnn": "500507631295741c",
"wwpn": "500507631295741c"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
alias
mapping |
string |
This field will no longer be supported in a future release. Use aliases.mapping instead. |
name |
string |
This field will no longer be supported in a future release. Use aliases.name instead. |
aliases
mapping |
string |
Alias mapping. |
name |
string |
Alias name. |
device_names
no_rewind_device |
string |
Device name for no rewind. |
rewind_device |
string |
Device name for rewind. |
string |
Device name for unload or reload operations. |
_links
self |
node
_links |
name |
string |
uuid |
string |
position
count |
integer |
Number of times to run position operation. |
operation |
string |
Position operation. |
storage_port
name |
string |
Initiator port. |
tape_device
alias |
aliases |
array[aliases] |
block_number |
integer |
Block number. |
density |
string |
Density. |
description |
string |
device_id |
string |
device_names |
array[device_names] |
device_state |
string |
Operational state of the device. |
file_number |
integer |
File number. |
formats |
array[string] |
Tape cartridge format. |
interface |
string |
Device interface type. |
node |
online |
boolean |
position |
reservation_type |
string |
residual_count |
integer |
Residual count of the last I/O operation. |
serial_number |
string |
storage_port |
type |
string |
Device type. |
wwnn |
string |
World Wide Node Name. |
wwpn |
string |
World Wide Port Name. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
