Manage multi-admin-verify rules
Multi-admin-verify rules safeguard critical ONTAP operations by requiring approval from multiple administrators before execution. Use these endpoints to define which operations need extra verification, enhancing security for sensitive commands.
Overview
Rules define the ONTAP commands (operations) that should be protected by multi-admin approval.
While the feature is turned on, any ONTAP operation that is defined with a rule will be enforced with multi-admin approval to execute the command (operation).
Creating a multi-admin-verify rule
Creates a rule for the specified ONTAP operation.
# The API:
/api/security/multi-admin-verify/rules
# The call:
curl -X POST "https://<mgmt-ip>/api/security/multi-admin-verify/rules?return_records=true" -H "accept: application/hal+json" -d '{"owner.uuid": "c109634f-7011-11ec-a23d-005056a78fd5", "operation": "volume delete", "query": "-vserver vs0", "required_approvers": 1}'
# The response:
"num_records": 1,
"records": [
"owner": {
"uuid": "c109634f-7011-11ec-a23d-005056a78fd5",
"href": "/api/svm/svms/c109634f-7011-11ec-a23d-005056a78fd5"
"auto_request_create": true,
"required_approvers": 1,
"create_time": "2022-01-07T22:14:03-05:00",
"system_defined": false,
"href": "/api/security/multi-admin-verify/rules/c109634f-7011-11ec-a23d-005056a78fd5/volume%20delete"
Retrieving multi-admin-verify rules
Displays information about multi admin verification rules.
# The API:
# The call:
curl -X GET "https://<cluster-ip>/api/security/multi-admin-verify/rules"
# The response:
"records": [
"owner": {
"uuid": "52b75787-7011-11ec-a23d-005056a78fd5",
"name": "cluster1",
"href": "/api/svm/svms/52b75787-7011-11ec-a23d-005056a78fd5"
"operation": "security login password",
"href": "/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/security%20login%20password"
"owner": {
"name": "cluster1",
"operation": "security login unlock",
"href": "/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/security%20login%20unlock"
"owner": {
"name": "cluster1",
"operation": "security multi-admin-verify approval-group create",
"href": "/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/security%20multi-admin-verify%20approval-group%20create"
"owner": {
"name": "cluster1",
"operation": "security multi-admin-verify approval-group delete",
"href": "/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/security%20multi-admin-verify%20approval-group%20delete"
"owner": {
"name": "cluster1",
"operation": "security multi-admin-verify approval-group modify",
"href": "/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/security%20multi-admin-verify%20approval-group%20modify"
"owner": {
"name": "cluster1",
"operation": "security multi-admin-verify approval-group replace",
"href": "/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/security%20multi-admin-verify%20approval-group%20replace"
"owner": {
"name": "cluster1",
"operation": "security multi-admin-verify modify",
"href": "/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/security%20multi-admin-verify%20modify"
"owner": {
"name": "cluster1",
"operation": "security multi-admin-verify rule create",
"href": "/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/security%20multi-admin-verify%20rule%20create"
"owner": {
"name": "cluster1",
"operation": "security multi-admin-verify rule delete",
"href": "/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/security%20multi-admin-verify%20rule%20delete"
"owner": {
"name": "cluster1",
"operation": "security multi-admin-verify rule modify",
"href": "/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/security%20multi-admin-verify%20rule%20modify"
"owner": {
"name": "cluster1",
"href": "/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/volume%20delete"
"num_records": 11,
"href": "/api/security/multi-admin-verify/rules"
