REST API reference
Manage multi-admin-verify rules
The multi-admin-verify rules endpoints define which ONTAP operations require approval from multiple administrators before execution. Use these endpoints to configure and enforce security measures on critical commands, ensuring that sensitive operations are protected by an additional layer of validation.
Overview
Rules define the ONTAP commands (operations) that should be protected by multi-admin approval. While the feature is turned on, any ONTAP operation that is defined with a rule will be enforced with multi-admin approval to execute the command (operation).
Creating a multi-admin-verify rule
Creates a rule for the specified ONTAP operation.
# The API:
/api/security/multi-admin-verify/rules
# The call:
curl -X POST "https://<mgmt-ip>/api/security/multi-admin-verify/rules?return_records=true" -H "accept: application/hal+json" -d '{"owner.uuid": "c109634f-7011-11ec-a23d-005056a78fd5", "operation": "volume delete", "query": "-vserver vs0", "required_approvers": 1}'
# The response:
"num_records": 1,
"records": [
    "owner": {
      "uuid": "c109634f-7011-11ec-a23d-005056a78fd5",
          "href": "/api/svm/svms/c109634f-7011-11ec-a23d-005056a78fd5"
    "auto_request_create": true,
    "required_approvers": 1,
    "create_time": "2022-01-07T22:14:03-05:00",
    "system_defined": false,
        "href": "/api/security/multi-admin-verify/rules/c109634f-7011-11ec-a23d-005056a78fd5/volume%20delete"
Retrieving multi-admin-verify rules
Displays information about multi admin verification rules.
# The API:
# The call:
curl -X GET "https://<cluster-ip>/api/security/multi-admin-verify/rules"
# The response:
"records": [
    "owner": {
      "uuid": "52b75787-7011-11ec-a23d-005056a78fd5",
      "name": "cluster1",
          "href": "/api/svm/svms/52b75787-7011-11ec-a23d-005056a78fd5"
    "operation": "security login password",
        "href": "/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/security%20login%20password"
    "owner": {
      "name": "cluster1",
    "operation": "security login unlock",
        "href": "/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/security%20login%20unlock"
    "owner": {
      "name": "cluster1",
    "operation": "security multi-admin-verify approval-group create",
        "href": "/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/security%20multi-admin-verify%20approval-group%20create"
    "owner": {
      "name": "cluster1",
    "operation": "security multi-admin-verify approval-group delete",
        "href": "/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/security%20multi-admin-verify%20approval-group%20delete"
    "owner": {
      "name": "cluster1",
    "operation": "security multi-admin-verify approval-group modify",
        "href": "/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/security%20multi-admin-verify%20approval-group%20modify"
    "owner": {
      "name": "cluster1",
    "operation": "security multi-admin-verify approval-group replace",
        "href": "/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/security%20multi-admin-verify%20approval-group%20replace"
    "owner": {
      "name": "cluster1",
    "operation": "security multi-admin-verify modify",
        "href": "/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/security%20multi-admin-verify%20modify"
    "owner": {
      "name": "cluster1",
    "operation": "security multi-admin-verify rule create",
        "href": "/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/security%20multi-admin-verify%20rule%20create"
    "owner": {
      "name": "cluster1",
    "operation": "security multi-admin-verify rule delete",
        "href": "/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/security%20multi-admin-verify%20rule%20delete"
    "owner": {
      "name": "cluster1",
    "operation": "security multi-admin-verify rule modify",
        "href": "/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/security%20multi-admin-verify%20rule%20modify"
    "owner": {
      "name": "cluster1",
        "href": "/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/volume%20delete"
"num_records": 11,
    "href": "/api/security/multi-admin-verify/rules"
