Manage multi-admin-verify rules
Manage multi-admin-verify rules to ensure that specific ONTAP operations are protected by requiring approval from multiple administrators. When this feature is active, designated operations are enforced to gain multi-admin approval before execution.
Overview
Rules define the ONTAP commands (operations) that should be protected by multi-admin approval.
While the feature is turned on, any ONTAP operation that is defined with a rule will be enforced with multi-admin approval to execute the command (operation).
Creating a multi-admin-verify rule
Creates a rule for the specified ONTAP operation.
# The API:
/api/security/multi-admin-verify/rules
# The call:
curl -X POST "https://<mgmt-ip>/api/security/multi-admin-verify/rules?return_records=true" -H "accept: application/hal+json" -d '{"operation": "volume delete", "query": "-vserver vs0", "required_approvers": 1}'
# The response:
"num_records": 1,
"records": [
"owner": {
"uuid": "c109634f-7011-11ec-a23d-005056a78fd5",
"href": "/api/svm/svms/c109634f-7011-11ec-a23d-005056a78fd5"
"auto_request_create": true,
"required_approvers": 1,
"create_time": "2022-01-07T22:14:03-05:00",
"system_defined": false,
"href": "/api/security/multi-admin-verify/rules/c109634f-7011-11ec-a23d-005056a78fd5/volume%20delete"
Retrieving multi-admin-verify rules
Displays information about multi admin verification rules.
# The API:
# The call:
curl -X GET "https://<cluster-ip>/api/security/multi-admin-verify/rules"
# The response:
"records": [
"owner": {
"uuid": "52b75787-7011-11ec-a23d-005056a78fd5",
"name": "cluster1",
"href": "/api/svm/svms/52b75787-7011-11ec-a23d-005056a78fd5"
"operation": "security login password",
"href": "/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/security%20login%20password"
"owner": {
"name": "cluster1",
"operation": "security login unlock",
"href": "/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/security%20login%20unlock"
"owner": {
"name": "cluster1",
"operation": "security multi-admin-verify approval-group create",
"href": "/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/security%20multi-admin-verify%20approval-group%20create"
"owner": {
"name": "cluster1",
"operation": "security multi-admin-verify approval-group delete",
"href": "/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/security%20multi-admin-verify%20approval-group%20delete"
"owner": {
"name": "cluster1",
"operation": "security multi-admin-verify approval-group modify",
"href": "/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/security%20multi-admin-verify%20approval-group%20modify"
"owner": {
"name": "cluster1",
"operation": "security multi-admin-verify approval-group replace",
"href": "/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/security%20multi-admin-verify%20approval-group%20replace"
"owner": {
"name": "cluster1",
"operation": "security multi-admin-verify modify",
"href": "/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/security%20multi-admin-verify%20modify"
"owner": {
"name": "cluster1",
"operation": "security multi-admin-verify rule create",
"href": "/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/security%20multi-admin-verify%20rule%20create"
"owner": {
"name": "cluster1",
"operation": "security multi-admin-verify rule delete",
"href": "/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/security%20multi-admin-verify%20rule%20delete"
"owner": {
"name": "cluster1",
"operation": "security multi-admin-verify rule modify",
"href": "/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/security%20multi-admin-verify%20rule%20modify"
"owner": {
"name": "cluster1",
"href": "/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/volume%20delete"
"num_records": 11,
"href": "/api/security/multi-admin-verify/rules"
