REST API reference
Manage resource tags
Utilize resource tags to organize and retrieve resources across the API based on specific tag values. Access endpoints to list, create, and delete tags, aiding in efficient resource management and tracking.
Overview
You can use this endpoint to list all of the resources in the API that have been tagged with a particular tag value. See the section labelled Tagging Resources for Tracking Purposes to find out more information about how to tag a resource.
The following examples show some ways that this endpoint can be used.
List all resources that are tagged for the test environment.
# The API:
/api/resource-tags/environment:test/resources
# The call:
curl -X GET "https://<mgmt-ip>/api/resource-tags/environment:test/resources"
# The response:
"records": [
    "href": "/api/storage/volumes/558949d1-d4cf-445e-ada5-e340dee6a581",
        "href": "/api/resource-tags/environment:test/resources/%2Fapi%2Fstorage%2Fvolumes%2F558949d1-d4cf-445e-ada5-e340dee6a581"
    "href": "/api/svm/svms/7f97a0b1-fe4f-11e8-b9c5-005056a76061",
        "href": "/api/resource-tags/environment:test/resources/%2Fapi%2Fsvm%2Fsvms%2F7f97a0b1-fe4f-11e8-b9c5-005056a76061"
    "href": "/api/cluster",
        "href": "/api/resource-tags/environment:test/resources/%2Fapi%2Fcluster"
"num_records": 3,
    "href": "/api/resource-tags/environment:test/resources"
List all volumes that have been tagged for the accounting team
# The API:
/api/resource-tags/team:accounting/resources
# The call:
curl -X GET "https://<mgmt-ip>/api/resource-tags/team:accounting/resources?label=storage_volumes"
# The response:
"records": [
    "label": "storage_volumes",
    "href": "/api/storage/volumes/64750961-fda7-4327-9f16-00034c3f5ad2",
        "href": "/api/resource-tags/environment:test/resources/%2Fapi%2Fstorage%2Fvolumes%2F64750961-fda7-4327-9f16-00034c3f5ad2"
    "href": "/api/storage/volumes/bee17b91-f90a-4854-b146-8b102a0a9882",
        "href": "/api/resource-tags/environment:test/resources/%2Fapi%2Fstorage%2Fvolumes%2Fbee17b91-f90a-4854-b146-8b102a0a9882"
"num_records": 3,
    "href": "/api/resource-tags/environment:test/resources?label=storage_volumes"
Create a new tag on a volume
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/resource-tags/team:accounting/resources" -d '{"href": "/api/storage/volumes/f288168e-bd3e-11ed-9516-005056acd4e8"}'
# The response
"num_records": 1,
"records": [
    "href": "/api/storage/volumes/f288168e-bd3e-11ed-9516-005056acd4e8",
        "href": "/api/resource-tags/team:accounting/resources/%2Fapi%2Fstorage%2Fvolumes%2Ff288168e-bd3e-11ed-9516-005056acd4e8"
Delete a new tag on a volume
# The API:
/resource-tags/{resource_tag.value}/resources/{href}
# The call:
curl -X DELETE "https://<mgmt-ip>/api/resource-tags/team:accounting/resources/%2Fapi%2Fstorage%2Fvolumes%2Ff288168e-bd3e-11ed-9516-005056acd4e8"
