REST API reference
Manage resource tags
Use resource tag endpoints to list, create, and delete tags associated with various resources. These endpoints help you organize and track resources by specific tag values, such as environment or team.
Overview
You can use this endpoint to list all of the resources in the API that have been tagged with a particular tag value. See the section labelled Tagging Resources for Tracking Purposes to find out more information about how to tag a resource.
The following examples show some ways that this endpoint can be used.
List all resources that are tagged for the test environment.
# The API:
/api/resource-tags/environment:test/resources
# The call:
curl -X GET "https://<mgmt-ip>/api/resource-tags/environment:test/resources"
# The response:
"records": [
    "href": "/api/storage/volumes/558949d1-d4cf-445e-ada5-e340dee6a581",
        "href": "/api/resource-tags/environment:test/resources/%2Fapi%2Fstorage%2Fvolumes%2F558949d1-d4cf-445e-ada5-e340dee6a581"
    "href": "/api/svm/svms/7f97a0b1-fe4f-11e8-b9c5-005056a76061",
        "href": "/api/resource-tags/environment:test/resources/%2Fapi%2Fsvm%2Fsvms%2F7f97a0b1-fe4f-11e8-b9c5-005056a76061"
    "href": "/api/cluster",
        "href": "/api/resource-tags/environment:test/resources/%2Fapi%2Fcluster"
"num_records": 3,
    "href": "/api/resource-tags/environment:test/resources"
List all volumes that have been tagged for the accounting team
# The API:
/api/resource-tags/team:accounting/resources
# The call:
curl -X GET "https://<mgmt-ip>/api/resource-tags/team:accounting/resources?label=storage_volumes"
# The response:
"records": [
    "label": "storage_volumes",
    "href": "/api/storage/volumes/64750961-fda7-4327-9f16-00034c3f5ad2",
        "href": "/api/resource-tags/environment:test/resources/%2Fapi%2Fstorage%2Fvolumes%2F64750961-fda7-4327-9f16-00034c3f5ad2"
    "href": "/api/storage/volumes/bee17b91-f90a-4854-b146-8b102a0a9882",
        "href": "/api/resource-tags/environment:test/resources/%2Fapi%2Fstorage%2Fvolumes%2Fbee17b91-f90a-4854-b146-8b102a0a9882"
"num_records": 3,
    "href": "/api/resource-tags/environment:test/resources?label=storage_volumes"
Create a new tag on a volume
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/resource-tags/team:accounting/resources" -d '{"href": "/api/storage/volumes/f288168e-bd3e-11ed-9516-005056acd4e8"}'
# The response
"num_records": 1,
"records": [
    "href": "/api/storage/volumes/f288168e-bd3e-11ed-9516-005056acd4e8",
        "href": "/api/resource-tags/team:accounting/resources/%2Fapi%2Fstorage%2Fvolumes%2Ff288168e-bd3e-11ed-9516-005056acd4e8"
Delete a new tag on a volume
# The API:
/resource-tags/{resource_tag.value}/resources/{href}
# The call:
curl -X DELETE "https://<mgmt-ip>/api/resource-tags/team:accounting/resources/%2Fapi%2Fstorage%2Fvolumes%2Ff288168e-bd3e-11ed-9516-005056acd4e8"
