REST API reference
Manage resource tags
Utilize the manage resource tags endpoints to list and organize resources based on specific tag values. Create and delete tags on existing resources to streamline tracking and categorization processes.
Overview
You can use this endpoint to list all of the resources in the API that have been tagged with a particular tag value and to create new tags on existing resources. Each resource has a limit of 64 tags that cannot be exceeded. See the section labelled Tagging Resources for Tracking Purposes to find out more information about how to tag a resource.
The following examples show some ways that this endpoint can be used.
List all resources that are tagged for the test environment.
# The API:
/api/resource-tags/environment:test/resources
# The call:
curl -X GET "https://<mgmt-ip>/api/resource-tags/environment:test/resources"
# The response:
"records": [
    "href": "/api/storage/volumes/558949d1-d4cf-445e-ada5-e340dee6a581",
        "href": "/api/resource-tags/environment:test/resources/%2Fapi%2Fstorage%2Fvolumes%2F558949d1-d4cf-445e-ada5-e340dee6a581"
    "href": "/api/svm/svms/7f97a0b1-fe4f-11e8-b9c5-005056a76061",
        "href": "/api/resource-tags/environment:test/resources/%2Fapi%2Fsvm%2Fsvms%2F7f97a0b1-fe4f-11e8-b9c5-005056a76061"
    "href": "/api/cluster",
        "href": "/api/resource-tags/environment:test/resources/%2Fapi%2Fcluster"
"num_records": 3,
    "href": "/api/resource-tags/environment:test/resources"
List all volumes that have been tagged for the accounting team
# The API:
/api/resource-tags/team:accounting/resources
# The call:
curl -X GET "https://<mgmt-ip>/api/resource-tags/team:accounting/resources?label=storage_volumes"
# The response:
"records": [
    "label": "storage_volumes",
    "href": "/api/storage/volumes/64750961-fda7-4327-9f16-00034c3f5ad2",
        "href": "/api/resource-tags/environment:test/resources/%2Fapi%2Fstorage%2Fvolumes%2F64750961-fda7-4327-9f16-00034c3f5ad2"
    "href": "/api/storage/volumes/bee17b91-f90a-4854-b146-8b102a0a9882",
        "href": "/api/resource-tags/environment:test/resources/%2Fapi%2Fstorage%2Fvolumes%2Fbee17b91-f90a-4854-b146-8b102a0a9882"
"num_records": 3,
    "href": "/api/resource-tags/environment:test/resources?label=storage_volumes"
Create a new tag on a volume
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/resource-tags/team:accounting/resources" -d '{"href": "/api/storage/volumes/f288168e-bd3e-11ed-9516-005056acd4e8"}'
# The response
"num_records": 1,
"records": [
    "href": "/api/storage/volumes/f288168e-bd3e-11ed-9516-005056acd4e8",
        "href": "/api/resource-tags/team:accounting/resources/%2Fapi%2Fstorage%2Fvolumes%2Ff288168e-bd3e-11ed-9516-005056acd4e8"
Delete a new tag on a volume
# The API:
/resource-tags/{resource_tag.value}/resources/{href}
# The call:
curl -X DELETE "https://<mgmt-ip>/api/resource-tags/team:accounting/resources/%2Fapi%2Fstorage%2Fvolumes%2Ff288168e-bd3e-11ed-9516-005056acd4e8"
