Completes a snapshot copy operation of a consistency group
the following example shows how to complete the snapshot copy operation by committing an existing snapshot copy to disk:
curl -x patch https://<mgmt-ip>/api/application/consistency-groups/a8d0626a-17a0-11eb-b141-005056acd498/snapshots/92c6c770-17a1-11eb-b141-005056acd498?action=commit
#### response:
PATCH /application/consistency-groups/{consistency_group.uuid}/snapshots/{uuid}
Introduced In: 9.11
Completes a Snapshot copy operation of a consistency group.
Example
Completing a Snapshot copy operation
The following example shows how to complete the Snapshot copy operation by committing an existing Snapshot copy to disk:
curl -X PATCH https://<mgmt-ip>/api/application/consistency-groups/a8d0626a-17a0-11eb-b141-005056acd498/snapshots/92c6c770-17a1-11eb-b141-005056acd498?action=commit
Response:
consistency_group.uuid |
string |
path |
True |
Unique identifier of the consistency group's Snapshot copy for deletion. |
uuid |
string |
path |
True |
Snapshot copy UUID. |
action |
string |
query |
False |
Commits the Snapshot copy. The commit must be called within the timeout value specified during POST. If the commit is not called within the specified time, then the Snapshot copy create operation is aborted.
return_timeout |
integer |
query |
False |
Status: 200, Ok
Status: 202, Accepted
Status: Default, Error
| Name | Type | Description |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
